Question about Pioneer PD-F1007 301-Disc CD Changer
Getting 'no disc'
After loading 10 CDs. and pressing play, the machine gave me 'no disc'. I tried the single use CD with same results. Please reply to krflint1@bellsouth.net. Thanks. Just purchased from e-bay and it worked one time.
  • 6,784 Answers
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc', code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Posted on Jul 26, 2009
One more time will play 22 cs ; only how to program?
On the Selection & Credit Computer (SCC), slide the service switch up to "ON" and press the LT button (also on the SCC). This will put the machine in service mode. You should then see either "10" or "00" on the display, depending on which CD player version you have.
Now press button 5; you'll probably see "2200" on the display, indicating 22 CDs programmed. To change, press and hold button 5. While pressing 5, press "R" and release both. Now, type in the number of CDs followed by "00". Press 5 again to show the programmed result. If correct, slide service switch back down to "OFF" and press LT again. Machine is now ready for operation. For further assistance, please email tech@wurlitzer-ohio.com.
Dec 12, 2010 | Wurlitzer Jukebox 1015 One More Time...
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Cd system does not recognise the cds on playing deck.
The unit is a 3 disc changer usually when these kind of problems occur there are quite a number of possible solutions.
When i faced such a problem it was due to the current being low. Then it was 200 volts instead of 220 so check yours and determine if the current is adequate otherwise you can get a voltage regulator.
On the other hand this happens when the lens is dirty or the CD is not properly placed but the second option is usually an off case.
Generally to solve the problem take out the unit from the mains for about 20 mins.
If you have the technical know how you can open the unit and try to clean around the CD tray. This should be done with utmost care as damageable components are around the tray(this is not compulsory if you cant).
After about 20 mins pug the unit back
Next get a CD lens cleaner and run it in the system to clean the lens of the unit.
put in a single disc and attempt to play. At this point the unit should function fine.
Hope this solution has been helpful?
Oct 07, 2010 | Teac DC-D4800 Shelf System
Cd's require a few loads before machine functions
Retail factory pressed CDs or CD-Rs ?
Did you try a Lens Cleaner disc?
Feb 03, 2010 | Audio Players & Recorders
Changer does not work
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
Thanks support guys for your help!!
I'm now a member!!
Jan 15, 2009 | Alpine CHM-S620 6-Disc CD Changer
About every 2 months our 6-disc CD changer breaks down and we have to have the whole radio replaced they said it comes from playing burned cds in it but it has even broken down with store bought ones. So...
I had the same problem i just decided to pull the whole thing out and get a new radio and single disc cd changer put in and so far it works fine.
Jul 26, 2008 | 2006 Chevrolet Equinox
Blaupunkt IDC-A09 5-Disc CD only plays the first 2 CDs
hi its broken :(
there is a repair kit for this model. you can get it from www.carradiospares.co.uk
its not that easy to fit, but fixes 9out of 10 cd problems
Mark
Jul 26, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
Pioneer PD-F1007 301-Disc CD Changer Logo
207 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
