After removing the driver side door, and replacing it i checked all electronics on the door before replacing interior panel, they worked.(locks, windows mirrors, on both sides) also i kept the wiring harness of my old door to assure it to be in working order.
i then put the interior panel back on, it was crooked, so i unplugged all the switches from the door, removed interior panel, put it back on strait and now the passenger window no longer works.
i have since removed both interior panels, checked all wiring in the doors that i have fiddled with and checked all fuses in the car several times.
i have NEVER had problems with any of the electronics before.
also, headlamp no longer works( it was iffy when i bought the car but eventually got it working, and light near ignition stays on, idk if it did before)
i assume a shorted/crossed wire somewhere, but where??
also on the passenger door i have tried running a wire from the battery to different wires in the harness of the passenger door and one of them turned my Radio off...
You blew the fuse for your radio.you cannot put a hot wire to a ground that is why the fuse blew.you could have broken a wire connector for the door,windows etc.the headlight switch wire harness is probably melted this happens a lot on Ford products,the head light draw so much heat they melt the wire harness plug that goes on the back of the headlight switch.
check for a ground on the door and the door jam switch,see it the door switch is adjusted to complete ground.
why are did you change the door?
Without seeing your car i can't go any further,sorry,Good Luck!
POWER WINDOWS NOT WORKING & POWER WINDOW/REGULATOR
ISSUES
It
can be issue with motor itself. If it's not going up, then how its working down.
But still it feels like weak window motor or is issue with power window switch.
Get the voltage tested at switch and motor. Also try another working window
motor at not working window side.
For
more troubleshooting i suggest go through the help links mentioned below:-----
Its
complete details with troubleshooting steps:------
Car windows will go down but come right back up
http://schematicsdiagram.blogspot.com/2011/06/car-windows-will-go-down-but-come-right.html
Power windows will not go up and relay clicks when switch is
pressed?
http://technoanswers.blogspot.com/2012/01/power-windows-will-not-go-up-and-relay.html
Electric Window Motor REMOVAL and INSTALLATION on ford
vehicles?
http://schematicsdiagram.blogspot.com/2011/06/electric-window-motor-removal-and.html
Driver side power window wont go up on ford expedition?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
How to replace window motor and regulator on jaguar S-Type?
http://howtobyme.blogspot.com/2011/09/how-to-replace-window-motor-and.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
power locks, power window and power mirror on the passenger side not working on
Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working on 2003 Cadillac CTS?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove the door panel to install a new window regulator on Cadillac
Deville?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
How to Remove Electric Window Motor on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-electric-window-motor-on.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
How to replace power window regulator for 2006 Dodge Dakot
How to remove passenger side power window motor on Dodge Grand Caravan?
http://schematicsdiagram.blogspot.com/2011/09/how-to-remove-passenger-side-power.html
How to replace automatic window motor unit for the front passenger side on 2001
jeep grand cherokee Laredo ?
http://schematicsdiagram.blogspot.com/2011/09/how-to-replace-automatic-window-motor.html
how to replace passenger side power window motor on 2001
Dodge van
All power windows not working on mercury sable?
http://technoanswers.blogspot.com/2011/09/all-power-windows-not-working-on.html
How to replace electric window regulator for mitsubishi 380 ?
http://technoanswers.blogspot.com/2011/09/how-to-replace-electric-window_05.html
how to remove window motor on driver side door panel on 1994 Oldsmobile Cutlass
Ciera
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
driver side window problem on Mercury Sable
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
How to remove door panel, door window motor and regulator on 1991 cavalier?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
how to replace the power window switch on 2005 BMW 325i?
http://technoanswers.blogspot.com/2011/03/how-to-replace-power-window-switch-on.html
How to replace window switch on bmw?
http://technoanswers.blogspot.com/2011/03/how-to-replace-window-switch-on-bmw.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
How to Replace a Window Switch on a 2002 Ford Explorer ?
http://technoanswers.blogspot.com/2011/02/how-to-replace-window-switch-on-2002.html
Ford F-150 Power Windows Not Working?
http://schematicsdiagram.blogspot.com/2011/12/ford-f-150-power-windows-not-working.html
Power windows works intermittently?
http://schematicsdiagram.blogspot.com/2011/12/power-windows-works-intermittently.html
Pontiac grand am
power window not working?
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Auto open close feature not working for Toyota Avalon?
http://technoanswers.blogspot.com/2012/01/auto-open-close-feature-not-working-for.html
Lexus ES300 Power window out of time?
http://repairhelpcenter.blogspot.com/2012/01/lexus-es300-power-window-out-of-time.html
Rear power windows not working on Ford Mustang?
http://technoanswers.blogspot.com/2012/01/rear-power-windows-not-working-on-ford.html
All power windows not working on Ford Explorer?
http://technoanswers.blogspot.com/2012/01/all-power-windows-not-working-on-ford.html
2003 Chevy impala power windows not working?
http://technoanswers.blogspot.in/2012/02/2003-chevy-impala-power-windows-not.html
Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
All Power Windows Not Working
http://whatisbyme.blogspot.in/2012/07/all-power-windows-not-working.html
1977 Chevrolet Corvette Power Windows Not Working?
http://technoanswers.blogspot.in/2012/04/1977-chevrolet-corvette-power-windows.html
These
details will help.
Thanks.
Electric Window Motor REMOVAL and INSTALLATION on ford vehicles?
Ford Windstar
Deville?
--------------How
window motor on 2001 Dodge van
Ciera
Pontiac grand am power window not
working?
sorry by headlamp i didn't mean the headlamps.
i meant the light above your head, that may or may not turn on wen u open the door.
i checked the bulb, it was fine i originally had just rotated it and it worked(before the door swap) but now no longer works. bulb is still good.
NO fuses were blown.
the door was replaced because of a rollover accident.
car was fine but a sign dented up the entire driver side.
the fender was also changed out.
grounding it did not work, also power locks work on both doors(both driver and passenger switch) and power mirrors both work and always have since the swap.
