Remove all of the paper from the tray and shine a flashlight into the printer. Look for any torn pieces of paper or other debris that could be blocking the paper sensor.
Pull the paper guides back as far as they will go, then reload the paper tray. Push the paper guides until they are tight against the paper on all sides. If the paper guides are loose or not properly adjusted, the printer may not sense that the paper is in place.
Look inside the printer if you have a unit with a single paper tray. Locate the print rollers, then look for a small plastic flag that moves up and down when the paper feeds into the printer. Jiggle this paper flag until it moves freely. If the paper flag is out of place the printer may not recognize that there is paper in the tray.
Pull each tray out of the printer carefully if you have a unit with multiple trays. Find the print rollers and the paper flag. Jiggle the paper flag until it moves up and down freely, then replace the tray.
If you need any technical help on printer then you can reach at
http://www.vtechsquad.com/
