Question about Sony Handycam DCR-TRV350 Digital Camcorder
Error code c 31 22 and it says to install a cleaning head tape (I guess it's dirty) on a handycam trv-138
  • Sony Master
  • 586 Answers
Actually this problem is related to the loading of tape path which get misaligned, most of the times improper insertion of cassette caused this problem and secondly dust/dirt in the gears of mechanical could be the cause. In this situation cleaning and mechanical adjustment is required, and mechanical adjustment bit difficult and only expert can perform this, therefore i advise for an expert to sort this problem.
Hope you will understand my sayings.
Thanks for using fixya.
Posted on Jul 26, 2009
Tape head dirty error after cleaning tape heads with tape cleaning cartridge
Hello, just a guess, but maybe you're using an old cleaning tape that has no more cleaning cycles left in it. Can I suggest you try a brand-new cleaning tape?
Regards,
nicam49
Dec 22, 2010 | Dell PowerVault 110T LTO-2 Ultrium Tape...
My sony hi8 Handycam TRV 138 gives me a message reinsert tape What is wrong? do it need repair
The cassette is not being detected when the tray is landing. If the head is not spinning but you are getting the cassette ejected then it is a malfunction of the loading mechanism. Even if the tape end detection optocouplers are defective the fault could be so.If you can check this out then try and test the voltage before and after the cassette loads. there should be a change if not replace. check on the loading mechanism too. Hope this helps. Good day
Jun 28, 2010 | Sony Hi8 Cleaning Cassette / Head Cleaner...
I have a sony ccd trv 138 hi8
it seams that it has a usb streaming /connection feature..so all you need its a driver and a cable to connect it to a computer ..
http://videodrivers.es/analog-8mm-hi8-camcorders-version-10-cd-mavica-camera-version-10-cyber-shot-cameras-versi/download-110.html
all I found its a driver for hi8 camcorders but it seams that is for windows 2000 ...anyway some drivers work on xp just fine even if they were build for 2K ...its worth a try ...if not ..you can get a alder cheap computer and keep it with 2000 ( if we dont find the xp driver ) ...just for downloading and operating this camcorder...
Sep 04, 2009 | Sony Handycam CCD-TRV37 Camcorder
Blue screen on TRV 260 playback
tape head is damaged. sometimes the internals unwind on the head if not done properly.
Jun 01, 2009 | Sony Handycam DCR-TRV260 Digital Camcorder
TRV-350 playback problem
Sounds like dirty heads. Get a head-cleaning tape and run that.
Dec 29, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
PLAY BACK
If the sound track of the recording you are playing is perfect and the noise is coming after you received dirty head error, there must be :
1) sometimes the tape ribbion leaves fine black dust on the drum, below the video head. If you look closely, the video head is in two parts. the lower part is stationary, which has a slanting guide for the tape ribbion to move on. The fine black dust deposites on this guide, disturbing the proper contact of the ribbion with the head, resulting in distorted sound. Once removed the play back is normal. You can blow it off or remove it by fine brush.
Nov 12, 2008 | Sony Handycam DCR-TRV265E Digital...
Reinsert casette tape
I suggest to clean tape head directly w/ QTIPS and the solution to clean video heads , clean and try again , thanks AJ
May 03, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
D8-->Hi8 switch.
Hello DutchyFL,
Sony recomends to use Video Head Cleaning Cassette in Playback mode. Video Head is still dirty in your camera thats why you can't see D8 picture.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Head-Cleaning Tape not Working
Another post here noted yet another discussion about giving the camera a whack on the side. This is not a good idea but since it fixed it points out that it was unlikely it was something the tape cleaner would fix. This likely means a trip to the repair depot.
Sep 14, 2005 | Sony Handycam DCR-TRV120BT Digital...
Sony Handycam DCR-TRV350 Digital Camcorder Logo
763 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
