Question about Sub-Zero 690 Side by Side Refrigerator
Freezer door light switch sticks, have to pull on switch nob.
Ice seems to form inside the switch at the bottom that is held closed by a closed door. or else the switch sticks and the light does not come
on when the door is opened. ... A little pull on the switch plunger and
the light comes on as it is supposed to do. How do I make the switch
plunger work more freely ? ?
  • 398 Answers
Sand it with 600 grit sand paper. and spray some lube W-D-40 on it.
Posted on Jul 25, 2009
My freezer door wont open, feels locked on one side. water is leaking underneath
Just answered a similar question about this but with the water leaking in this one, I think the door got wedged open slightly and you now have an excessive ice buildup on the inside of the freezer causing the door to stick from the ice buildup. You may need to pull hard to break loose the ice and when you get the door open clean all excessive ice from around the door seal area. Packages inside may need to be re- arranged so door closed properly.
Mar 05, 2015 | GE Profile Stainless Bottom-Freezer...
Freezer defrost working but leeks
Hey friend, I appreciate the post!
I understand that your refrigerator is defrosting but you are getting a patch of ice to form due to water leaking inside the freezer. It may be a moisture build up in your freezer. Which may be caused by the door being slightly opened, when that happens warm air can enter the refrigerator and cause a moisture build up. You could also check to see if your door seal is bad, the way to test that is to place a dollar bill between the body of the refrigerator and close to the door. Pull the dollar bill out, if it sticks it is good, but if bill comes out easily the gasket need to be checked. Hope this is helpful- Matt
Jul 19, 2014 | Frigidaire Refrigerators
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
I have ice buildup inside the door and on the shelves inside, and on the bottom. The compressor is running and the temperature is fine, everything freezes. The ice that forms is crystalized around the...
all you can do now is, slitly twist the freezer door. open the door an twist in twards the slite crack side. don,t over do it. a dollar bill, should be able, to be held in place, between the seal. then you will know you have a good seal. Don't tuch the hinges!!
Jul 03, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice if forming along top gasket area and side of freezer where
If we have ice on the inside of the freezer it means air is being pulled into the box somewhere. The most likely place is the door seal, it sounds like you already checked it, but I would suggest that you look very close at the bottom and aides of the seal too, it could be leaking in air from there. Check the inside liner for cracks and seal them if you find any. Look at the corners of the cabinet to make sure there is not room for air to come in.
Air leaks will lead to frost, it is just hard sometimes to find where it is leaking in.
Apr 13, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
ICE GATHERS AROUND THE DOOR OF THE FREEZER COMPARTMENT
very possible the door seal is bad. Take a dollar bill and close it up in the door and see if has some resistance when you pull it out if not the seal needs replacing.
Jan 24, 2010 | Amana ABB1927DE Bottom Freezer...
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
FREEZER IS FORMING ICE IN VERY BOTTOM AND CAUSING DOOR TO STICK
first of all, defrost the freezer. after that swich off your refregerator for about 8hrs and place the thermostart point on 3...............now try it. i'm sure that your problem will be solved
May 15, 2009 | Viking Professional VCBB363 Bottom Freezer...
Ice forming where ice comes out to refrigerator
I am not sure if this is the same issue or not.  the flap that closes after you have dispensed ice does not close or seal all the way.  The gasket is worn down. the result is warm air get up into icemaker and warms ice and refreezes in one block so now the dispenser gets blocked.  We had to replace the flap in the door.  bought the part at an appliance part  store (not sears) they were helpfull and looked up the part needed.  Also a sheet of ice forms on the  bottom of the freezer.  When water is dispensed a small bit drips inside freezer in back and runs down to botom of freezer slowly forming a sheet of ice.  Use a hair dryer to defrost and then you must unclog the drain in the back at the bottom of ffreezer to allow it to drian.  Once we finally unclogged the drain we have not had any problems for about 2 years.
Nov 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Sub-Zero 690 Side by Side Refrigerator Logo
252 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
