Hello friend, thank you for your post!
I understand you would like to reset the temperature on your Frigidaire freezer, LFFH17F7HWH. The best way to reset your freezer is to disconnect power from it for at least ten minutes. The factory recommended temperature for your freezer should be set to 0°F. If you need any additional assistance please feel free to reconnect. Hopefully this information is helpful to you. -Matt
I appreciate your post, Clayton!
From the information you have provided the display board on your Frigidaire freezer reads "OF". That reading means your freezer is off, you should be able to turn it back on by pressing the up or down arrow five times in a row. If you need any additional assistance please feel free to reconnect. I hope this is helpful to you. -Matt
Thank you for your post, michael!
I see that the alarm inside your Frigidaire freezer continues to beep it sounds like a potential issue within your control panel or thermistor. Your alarm will beep to inform you that the inside of your freezer is reaching high temperatures. Performing a reset on your appliance could help correct the problem, to perform a reset you need to unplug your freezer or flip the household circuit breaker off for ten minutes. I hope this has been helpful. -Matt
Hey Rene S, thanks for your post!
In order to reset your Frigidaire refrigerator you would need to disconnect power from it for roughly ten minutes. You can do that by unplugging it or flipping the household circuit breaker. If that does not correct your cooling issue I would recommend contacting a professional to come out and diagnosis your appliance to avoid any unnecessary part purchases. -Matt
