Question about GE WBVH6240F Front Load Washer
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
  • 6,784 Answers
HI. This is a Water temperature sensor error.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.(Most common issue will be a failed water temp sensor)
Posted on Jul 26, 2009
It stops it beeps it flashes F5 it's a whirlpool duet front load washer
When this happens press and hold any key down for one minute to clear f5 code
Apr 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool duet front load beeped and flashed f with no numbers and stopped mid-cycle. now what. i've pushed red button x2 and tried spin/drain and nothing. now it is stopped again. help!!
In many cases these error codes can be erroneous. If you reset the Central Control Unit (the Main Control for the washer), in many cases, the problem will clear. You must unplug the washer for AT LEAST 30 minutes in order to do this, however. If an error code returns following a CCU reset, then you have a legitimate problem.
Feb 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE WBVH6240F Front Load Washer Logo
191 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
