Question about Plumbing
Diamond shallow well jet pump wont rotate, froze up.
I have a diamond shallow well jet pump model # SJC50, 230V, 4amps, 60Hz, .5 HP that froze up and wouldnt turn over. I've taken it apart and dont see anything that would cause it not to rotate. circuit breaker keeps kicking off when the over temperature switch kicks on.
  • Anonymous Mar 29, 2014
    i am using it in a shallow well
  • 398 Answers
You need to look at the start capacitor, check it with a meter, look at, and spin bearings. make sure they spin free
Posted on Jul 25, 2009
Blade wont spin
Impeller is loose on the shaft, or coupling is broken if it has one.
Jul 30, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Gourds 1 hp model c48a95a06 has very loud sound when running
Jet pumps are inherently noisy, has it always been this loud? Loud is a subjective measurement and varies from person to person.
Mar 14, 2014 | Flotec Corrosion Resistant Shallow Well...
Cracked water pump
You should be able to replace the housing if you contact the manufacturer.
Mar 12, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
Nov 02, 2012 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
May 15, 2010 | Flotec Corrosion Resistant Shallow Well...
What value starter capacitor for 1/6 hp Flotec sump
when a motor burns out this will happen , replace the pump.
Apr 02, 2010 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
311 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
