Question about Microsoft Windows XP Home Edition SP2
Feeds synchonization keeps appearing i delete it but it returns every 2 min regardless of what i am doing it does not seem to stop anything working error report is feeds synchronization appname msfeedssync.exe appver 8.0.6001.18702 modname user32 dll mod ver5.1.2600.5512 offset 000095c8
    President:
  • Microsoft Master
  • 1,996 Answers
This is your IE browser checking for updated rss feeds...you can disable it if you wish to... or adjust the frequency with which it checks for updates
In IE,
Go to Tools\Internet Options
Select the Content tab
Settings button in the Feeds section.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 25, 2009
Dryer keeps stopping
Is the heater working?
Apr 03, 2017 | Dryers
Printer not printing, only a page of a 2 page article.
you did not stated what computer and what operating system, telepathy do not work very well...
i assume that printer is connected via wireless? and you operate some flavour of windows?
if that is the case, please follow procedure below:
1. open notepad
2. type exactly lines below:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
3. save as on desktop: DeletePrintJobs.cmd (do not delete it after! you may need it in years to come!)
4. click on it with right mouse button and then left mouse button and run as an administrator, this commands will delete all spooling jobs for the printers, regardless of the brand.
5. reboot your computer
if this did not work, then follow procedure below, this is true towards usb as well as wireless:
1. switch off printer and disconnect power cord to it
2. remove all drivers for the printer
3. run procedure from above then after restart
4. use ccleaner and clean your computer as well as registry
5. re-install printer using newest drivers appriopriate for your operating system, be it 32bit or 64bit as this is most common cause of this printer mis-behaviour
6. re-connect the printer
re-examine your wireless settings and set it as follows:
1. download and update from router manufacturer your firmware for your router, model and version
2. set SSID broadcast, change if you want to
3. set security to "WPA Personal", "WPA-PSK (TKIP)
4. set password, it need to be at least 12 characters (mixed!) long, do not use dictionary or common words!
5. set mode to "b" and "g", or if available on all your devices "n"
6. set channel to 1 or 6 or 11, these are most clear channels for most devices
7. disable/skip MAC address filtering
8. keep DHCP settings
9. save all changes
10. reboot router after changes, it will take up to 2 min
11. switch off all systems
12. re-power everything after 20sec
13. re-establish all connections
this procedure should keep your wireless connection at optimum and life relatively easy.
if you find my advice useful, please do nto forget to vote for me
Jul 31, 2010 | Dell V313w AllInOne InkJet Printer
Consew CP206-R Stopped Sewing/Working
Hi there, please send me an email and I will send you the mechanics book for your machine.
Kindest Regards,
Richard.
sewingmachines@gmail.com
Oct 24, 2009 | Sewing Machines
Load Paper indicator problem - Canon LBP5000
You should have a cancel button on the printer press that and hit cancel job. if that does not fix it unplug the printer for a few min and it will clear. make sure when you send an envelope to one of these you select the right paper type and "manual feed" in your printer options so you do not cause this again.
Jun 22, 2009 | Office Equipment & Supplies
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Lower right thread (green) keeps coming out of its eye!
Dear Louise I had the same problem and it was suggested to me that I change the needles as one of them could be bent. I have done this and the problem is no more. Good luck sewhat
Apr 05, 2009 | Janome MyLock 644D
Nikon Coolpix L18 keeps freezing
Put in a new set of batteries and then before you do anything else format the SD card using the camera.
Dec 21, 2008 | Nikon Coolpix L11 Digital Camera
Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Sep 19, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Synchonizing
The cleanest way is to start from scratch. Format the drive and reload. I use Windows Media Player. It works pretty well with the Sansa.
Mar 16, 2008 | SanDisk Sansa e250 MP3 Player
Microsoft Windows XP Home Edition SP2 Logo
209 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
