Battery weak and pto shut off after reversing never came on again
SOURCE: cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
SOURCE: Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
SOURCE: Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
SOURCE: PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
