Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
90hp mercury will start but not run
1996 90 hp 3-cyc mercury--* will start but cuts off--acted like running out of gas---not the problem---1 filter under hood is ok-- on water hose now--- can keep running a little by playing with choke and throttle---i do not want to over look weak fire ---- do not know which way to go--- not a rocket doctor or real smart but can replace the part if i knew which one---- finding problem it most of the time my biggest problem---last two times i was out it seemed it fell out for just a split second and then picked right back up boat it used right much so i don't think setting up is the problem but i do not know
thanks for any help
allen
  • 636 Answers
Check the wires leading to the CDI box for cracks or wear. Not there to know what is really going on but it could possibly be this or bad gas? drain gas and try some fresh stuff, also look for a good conditioner which will clean depots out of the carb. Hope this helps.
Posted on Jul 25, 2009
  • 57 Answers
Could be needle and seat in carby sticking-or possiblylow fuel pump pressure-dirty fuel filter-blocked pinched fuel line-fuel tank air vent open?
Posted on Oct 15, 2009
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Gas problem 90hp mercury 4 stroke
have you cleaned the carbs or injecters pending which you have ?
Aug 11, 2014 | Clymer Mercury/Mariner 4-90 HP Four Stroke...
My 2000 mercury Mystique will not start when it is cold
sounds like you have a fuel problem either pump of filter .
Nov 23, 2017 | 2000 Mercury Mystique
Will not run under load, seems to be starving for fuel. When I leave it for a minute or two, I can start it and work with it for a minute or so then it sees to over rev before cutting out. If I start it...
Check the fuel filter in the tank for plugging. Check the fuel lines for kinks, rotting, or splits. Check the muffler and air cleaner for plugging. Make sure all the screws and mounting nuts are tight on the carburetor. When these things look ok, then turn the H needle jet CCW about 1/2 turn, start the engine and let it warm up. Open the throttle fully--the engine should be 4-stroking now. Proper adjustment is when the engine will 4-stroke, but immediately 2-stroke when cutting. You may need to turn the H needle somewhat CW to achieve that condition. Hope this helps!
Apr 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 1987 yamaha ,3 cyl 50 hp. just cut right
Check a couple of things.
1. Make sure that the carb is getting fuel.
  • Check the vent on the tank for blockage - look for bug, spider web dirt gunk.
  • Check the output of the fuel pump. It should give you a nice steady stream of gas.
2. Is the engine overheating? When was the last time the water pump impeller was replaced?
Aug 06, 2009 | Boating
98 sebring
check the cable at ecm if it is pulled to tight up or down this will put stress on the pins and result in a car that runs like it needs a tuneup
Nov 09, 2017 | 1998 Chrysler Sebring
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
1,048 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
