Question about Quartet gbc 4220S Shredder
Need part number 1752126 for a 4220s machine. this is a control board.
My kenmore washer model number 11027086602 washes and stops and a code shows on the screen f1
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
After i turn the washer on and as the door locks a f1 error appears I stop the machine and restart the machine and it will finish the load of clothes
http://www.servicematters.com/maytag_library/docs/16022937.pdf
use the service manual above to troubleshoot your issue. http://www.washerhelp.co.uk/diy-repair-help.html The F1 error code on this washer indicates a Primary Control Board failure. It is likely that the machine control board will need to be replaced to correct this problem. The part number for the machine control board is 8576385. You can order this control board from the Sears PartsDirect website www.searspartsdirect.com . This part will substitute to new part number W10201186.The procedure for replacing the machine control board is provided in the image below. NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem. A pinched or twisted air hose can cause this fault code. When you open the console, check the air hose connected to the pressure switch on the machine control board. If it is pinched or crimped, I recommend rerouting the hose to resolve this problem. This may fix your problem without replacing the control board. NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself. As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Jun 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Display does not light up at all
If the 120VAC wahser service outlet has power and the machine LED Control Console for the FAV6800AW or LCD screen for the FAV9800AW appeares to have no power then I feel you have a Control Board failure. If you post your model number we can give you and aproxmate cost of the Control Board. The Control Board is under warranty for 5 yr. If you call Maytag customer service at 1-800-688-9900 they will need your Model Number and Serial number located on the rear top right of the console.
The above machine types do not have an internal fuse or circuit breaker to check.
Nov 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore Oasis top load washer. Model # 110.27072602 S/N CT4670250. F1 code issue and not able to get the update/recall controller board. Does any one how I can get the recall or part number I need to fix...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Nov 04, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My 1999 model maytag neptune washing machine's door lock light does not come on and it won't spin all the water out. What do I need to replace or check? I want to fix this myself and I just need a part...
take the control panel apart
3 small screws on top
look for the control board
your looking for any obvious signs of burn
thats the lock resistor r-11
you will need two parts here
a wax motor and machine control board
the wax motor was your problem
it took out the board
1999 sounds like the mah3000
ive included the part numbers for that model
AP4026826 machine control 181.00
AP4026523 wax motor 11.97
call
1-877-477-7278
two part repair but a 5 on a difficulty outa 10
Oct 09, 2009 | Washing Machines
Kenmore elite oasis top load washer on display F-- "F(no number) code on my washer
May 03, 2009 | Washing Machines
Motor control board needs replacing
You need to get the model number off the door jam or from the back control panel to order the correct board.
Looks like the right one to me you have listed already , once you get the part number for the actual motor board then you can search on line for the best price on one.
Phil
Apr 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Stopped 10 mins into cycle
Jan 11, 2009 | Washing Machines
What was part number
May 12, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Water supply
look on the control board. there's some DIP switches. these are set according to the number of coins needed to run the machine. the coin acceptor reads the number of coins going through it and advances the control board one increment for each "good" coin. objectionable coins are rejected.
Sep 06, 2007 | Maytag MAT12CS Top Load Washer
Quartet gbc 4220S Shredder Logo
138 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
