The air is coming out warm or room tempature. its not cold air at all
  • 146 Answers
Hello
Well have you checked to see if the condenser is coming on?
 And if not, then you need to check to see if there is a burnt fuse, usually right next to the unite. You can also go and check to see if a breaker has fillip. Because most condensers are on a dedicated breaker. Try that, hope it helps.
Posted on Jul 26, 2009
Jiffy ice auger won't start if cold model 30 start good room tempature
Piece of junk if it needs to be warm.....being an ice auger and all.....take it back if you can.
Jan 10, 2017 | Refrigerators
Sometimes it blows out warm air warm enough to warm an entire room, yet at other times is blows cool air that can kkep a room cool. I want it to blow cold at all times. how do i do that?
dry air feels cool on the skin
moist air feels warm on the skin
this is why the perceived temperature of air from unit changes
Apr 14, 2015 | Dehumidifiers
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
How come there is always a cold breeze coming down the chimney flue in the winter?
The answer is simple: the flue is left open so allow smoke to come out of the fireplace. You can by really simple contractions that lower flaps over the holes from the comfort of your living room. Try any home hardware store like Ace or Home Depot.
Jan 30, 2013 | Hardware & Accessories
Should the condensor coils be warm or cold
The condensor should always be blowing warm air. When warm air comes from the condensor this is the Freon being used to take warm temperatures from inside the refrigerator. If the air coming off the condensor is the same as room temperature it would indicate that the compressor is not running, If you have other questions please let me know, Thanks Sea Breeze
How a Refrigerator Works
Jun 27, 2012 | Amana Refrigerators
The unit will not produce cold air. It only pushes out room temp air. Altough I am not an expert, I think it is the compressor, or the tempature control unit (thermostat?) The unit does seem to make an...
I have a Amcor AF 1200E air conditioner, it only blows warm air and it is real dirty on inside filters, we took out 3 filters but there is still dirt on filters behind these, do we take it apart to clean, I would like a manual , do youknow where I can download one at? thanks
Sep 06, 2010 | Amcor AF9000E Portable Air Conditioner
2001 Alero- heat gage does not show heat tempature. Blows warm air.Engine felt cold after a 50 mile trip. Out side tempature 20 degrees fernaheight.
with winter being here you might want to consider having a new thermostat put in to increase the heat in side,but make sure your radiator is full when engine is cold
Dec 26, 2009 | 2002 Oldsmobile Alero
Fridge works freezer isnt getting cold enough to freeze
check to see if you have frost on the back panel of the freezer if so then defrost the unit and if your able to find the failure of the defrst heater or defrst thermostat,or the defrost thmer more than likely its the mother board since its a general electric frig but if you manually defrost until a repair tect can come then it will run normal until it frost up again but before you call the tech out make sure you have the frost on the back panel otherwise he'll make several trip trying to solve the problem with the frig unless its the defrst heater
Sep 08, 2009 | Amana Refrigerators
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
