Question about Kenmore Dishwashers
My washer fills with water then just makes a humming noise wont go into next cycle. model number 363.1556990
  • 115 Answers
Sounds like a lid switch jumper it and seeif that works you will have to take machine apart to get to switch
Posted on Jul 26, 2009
2 Suggested Answers
  • 79 Answers
SOURCE: whirlpool dishwasher will fill with
Your pump could be jammed or plugged. Make sure the grate in the bottom of the washer is clean. If possible, pull it out and look under it to see if there is anything in the hole.
Posted on Jan 08, 2011
Whirlpool dishwasher will fill with water but washer cycle wont kick in just makes a humming noise
Jan 08, 2011 | Whirlpool Dishwashers
Washing machine wont fill with water, just hums. Spin works fine, just wont fill with water.
The humming noise is caused by the water valve solenoids trying to open. You will need to remove the hoses from the back of the machine and see if there is any calcium or water deposit on the screens in the water vavles. If there is try cleaning it out and testing, if there is none, the water fill vavle will need to be replaced, you can order parts for it at, Reliable Parts by using your model number. Valve should cost around $45. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 19, 2010 | Whirlpool Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Machine stops at rinse cycle and hums
check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
Apr 26, 2009 | General Electric Clothes Washer Timer -...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Washer fills with water but wont continue washing cycle
Your lid switch is bad or loose.. open and close your lid and see if you can hear clicking noises.. if not.. then your lid switch is broken.. good luck
Jan 21, 2009 | Washing Machines
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
