check the freezing level, there will be level of the coldness for different levels. check whether you have adjusted it to the highest level or lowest level. if it is in lowest level then increase the level of it and just have a check, if you still persist the problem then you need to call the technician .
The Coolent which will be present in the backside of the refrigerator has got leaked, the leakage can be due to many reasons like damage in pipes where the coolent is passed to the different parts, due to the opening the refrigerator door for long of time the coolent leakage etc . are some of the reasons for it. you need to check the amount of coolent present inside the cylinder like container which is present in the backside portion of the refrigerator. If the amount of coolent present is less the desired amount then the cylinder must be filled with the coolent upto that amount, it will be a bit costly. it is a difficult task you need to call the technician itself ...
For further queries you can contact me You can rate this solution as per your satisfaction
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good...
(More)
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good or bad would be helpful. Thanks
the refridgerator shuts down (no power-lights off) when the either door slams. loose connection?...
(More)
the refridgerator shuts down (no power-lights off) when the either door slams. loose connection? what should i do?
my smeg fa550x seems to be defrosting itself, I had a job to open the door on the freezer side, it...
(More)
my smeg fa550x seems to be defrosting itself, I had a job to open the door on the freezer side, it had completely iced itself up from the ice maker at the top. can anyone help?
