Question about Ryobi Garden
Broken choke lever on Ryobi 30040a Trimmer. - Ryobi Garden
5 Suggested Answers
  • 57 Answers
SOURCE: Stops when given full throttle
Most likely carburetor needs adjustment.
Posted on May 15, 2009
panilling9
  • 284 Answers
SOURCE: ryobi 990r trimmer
alot of trimmers now have limiter caps on the carbruetors to keep the homeowner from making adjustments due to epa regulations and the ethanol fuel is 10% is not good either
So unless you have access to or a way to remove the caps for adjustments its a hard fix
you could remove the carb. and take apart to make sure the rubber pieces are still pliable.
the fuel will harden them over time and the carb will not deliver fuel to engine properly.
check you fuel lines to make sure they are not cracked or broken
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
Posted on May 29, 2009
  • 115 Answers
SOURCE: Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Posted on Jul 06, 2009
My Ryobi ry3002a weed trimmer won't idle. It shuts off as-soon-as I move the lever to run position. I disassemble and clean the carburetor but no luck. Any suggestion?
Run at 1/2 choke rev the engine & count to 10 showly. The engine should now be warm enough. If it still stalls, turn up the low idle screw.
Aug 24, 2015 | Ryobi Garden
I have a Ryobi HT26.In the back of the primer under before the gas tank is a choke lever and throttle lever.My choke lever is connected to nothing in the back or front of mygas diaphram.Does'nt it soppose...
If you remove the air filter you should see the choke butterfly valve on the air intake to the carburettor.
The choke lever should be connected to the axle of this valve on the outside of the carburettor.
Apr 13, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
How to start a kawasaki th48 2 stroke engine
Typically:
1. Press primer button 6-7 times until you see fuel flowing
2. Engage the choke lever to full choke /--/ pull cord 3-5 times until engine begins to start
3. Move choke lever to 1/2 choke and pull cord 2-3 times until engine starts - - allow to warm up (about 30 seconds) and move choke lever to no choke / / /
4. If engine does not start, repeat 1-3
If engine does not start, repost with more detail. Thanks! :)
Sep 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
PROPER WAY TO START TRIMMER.
Pump the primer bulb on the carburetor at least 7 times....set choke lever ( the yellow lever on the air cleaner) to the down start position....pull start handle till it fires....let machine run for about 30 to 45 seconds before you open the throttle to give it a chance to warm up....that's it !!! ;-D
Jul 05, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Jul 05, 2009 | Garden
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
Jim
May 29, 2009 | Ryobi Garden
May 15, 2009 | Garden
Ryobi gas trimmer stalls when lowering the revoutions
do you have the right kmix fuel to addat start on choke let run tell it dies then pump the ball on half choke and chage the plug
May 15, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
471 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
