SOURCE: 2002 Sebring LXi Convertible Starter Motor Fuse Blown 2x
Starter solenoid. I don't have the page here but in chiltons a page shows the ignition to fuse to relay to starter and if you look closely it's quite basic. I had same problem with constant fuse blow #8. The solenoid over time wears and sometimes sticks. When it sticks, your system can overload thus burn fuse. I bet you never stalled out while driving, but only when you shut off and start somewhere it's a no go. That's because you're system is already engaged. I had to change starter as solenoid part of it all. I see others suffer this same problem so please share this around. Solenoid can stick for a millisecond.
SOURCE: No power on 2002 Mitsubishi VS-60609
You've mad the right decison; fuses can fail due to metal fatigue as they flex a little each time current flows through them of ceases but a 2nd fuse is unlikely to fail instantly.
This indicates a true problem.
If you found the fuse, it was probably located on the main power supply board and this item has likely failed.
Look for an assembly number on that board and call a Mitsu service company and inquire about repair or replacement cost.
Either one can range from ~$75 to $150.
It would be interesting to know if the fuse blew as soon as the unit was plugged back in or only when you tried to turn it on with the remote or power button on the set.
If it blew only by plugging it in, that power board is the culprit.
If it blew as you tried to turn it on, it could be a failed 2nd power supply for the CRTs that is often located separate from the main supply where the fuse was.
About any E-tech could ferret out the which of the two is at fault so you might consider having a pro do the repair but if you know the failure sequence you might choose to gamble on making the decision yourself.
Good luck-
SOURCE: My 50
if the fuse was at the or near the AC plug chances are your got a power surge, if you did you got very lucky the fuse was there you might want to get a surge protector on the set ... But sometime you get just a defective fuse as long as the set is working I would not worry about it
SOURCE: Hotpoint dishwasher BF1620 blew the main fuse
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
SOURCE: Power seats and power windows quit
There are too many places to look. A couple of the places would be under your seat, see if a ground wire came loose. If you can get it on a computer and see what it turns up as. If you do not have access to a computer (and I do not mean your laptop or desktop ) than you can goto any mechanic and they will have one to put on it but it will cost more than your going to want to pay.
