Question about Samsung RB2155 Bottom Freezer Refrigerator
When you push the fridge door closed it pops back open
  • 286 Answers
Make sure the gasket is ok.(rolled over) You can raise the frosnt a little higher than the back. Or it could be a bad gasket
Posted on Jul 25, 2009
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
Freezer door opens when fridge door is closed
that is common, your pushing air back into the other side and that pops the door. First adjust the ref so that the back sits lower than the front. It will have 2 5/16th nuts on the front behind the kickplate. going left will lower the back of the unit. After that get out some vasoline and lube up the flat sides of the door seal, this will help keep the seal moist and it wont pop open as easy
May 01, 2012 | Maytag Refrigerators
Freezer door pops open
when you close the fridge door you create pressure in the fridge and the freezer door may pop open, close it more softly. or there may be stuff pushing against the inside of the freezer door
Mar 05, 2012 | Maytag Refrigerators
Freezer door pops open about 1/8" when you shut refrig door
this is very normal this means that you have an extremly good seal .. causing air to push threw duct work when closing door .... try changing the levelnes of refrigerator so when door does pop open it falls back closed meaning tilt fridge front higher than back of fridge
Feb 01, 2011 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Should my fridge be level or should the door close by itself
shuold be tilted back just a little so when you lightly push the door it will close all the way,if you have a level tilt it back like a 1/4 of the bubble in the level,if the freezer door opens when you shut the fridge door put something heavy on the inside of door so it won't pop open on you and wash around the area where the gaskets touch the frame so anything that might be sticky doesn't rip them,good luck and hope this helps you
Dec 18, 2009 | Kenmore Refrigerators
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
My freezer opens by itself after we close the fridge what can cause this
Is the refrigerator sitting on a level floor?
Are the freezer door or racks overloaded with food/packages such that the packages push the door back out?
Are any roll out drawers to full to fully close, including if something has fallen down behind them?
Jan 15, 2009 | Refrigerators
Samsung RB2155 Bottom Freezer Refrigerator Logo
75 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
