Question about Maytag Washing Machines
MILDEW ODOR - Maytag Washing Machines
    President:
  • 1,273 Answers
Clean out the strainer screen, located behind the kick panel, and run an extended empty HOT cycle with the hottest rinse selectable and an additional rinse. Put bleach in all cups.
Regards, --W/D--
Posted on Jul 26, 2009
Mildew oder coming from ac
The unit needs cleaning, the drain is possibly blocked which would cause the odor
Aug 04, 2014 | Heating & Cooling
We have a Persistent mildew odor left on our clothes?
Use boil wash with a little wash powder never use bleach not very kind to certain joints and seals, when finished leave door open overnight good luck PBK
May 01, 2014 | Washing Machines
We have a very foul in our mobile home, and we think it is coming from our empire heater! is there anything we can do to fix this odor
Oder doesn't seem to be electrical smell or you would know a house fire may occur. We normally know the electrical smell I'm worrying you about, and if it is that, do not use it and call a professional! It may be mildew in the unit or in the ductwork. Mildew is quit common, mold is not. No one LEGALLY can tell you it's mold unleased certified by you state or province. Mildew can grow anywhere we have a warm surface that comes in contact with a cold surface. This means uninsulated ductwork, or aged ductwork. The unit itself can also produce some mildew due to lack of maintenance. And also, water can get inside the duct for many reasons if you have cooling. If water is trapped it can produce "growing" stuff and a smell. Varmints can also cause this, either by dying inside the unit/duct or by leaving their droppings, to say it nicely. Temporary fix is what we call in Texas a Odor Cake. These are sold at the HVAC parts houses. Come in a little Tupperware style cup, and are mainly used for fire, smoke, and mildew damage to a structure. You just set em inside the airflow and the help, but don't solve the issue. If mildew is present inside the unit, have a tech out to inspect/clean. And a ultraviolet light may be needed to help control the growth. Internet U.V. Light for HVAC to study on them. Hope this helps!
Sep 04, 2017 | Empire Heating & Cooling
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Last few weeks there is a foul odor coming from the washer
How old of a unit? The new high energy effeciency washers are known for their "odors" due to the fact they dont drain out all water and it can mildew inside. Some solutions...leave door ajar after wash cycles , water will evaporate, there is products you can add every so many loads, one product being "affresh" ,,,some other people will run strong bleach load every so many loads it will kill mildew. These washeres have been out for years in Europe and they have same problems, its just inherent with product
May 21, 2009 | GE WSXH208A Front Load Washer
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Nepture washer Model MAH 5500 boot mildew
The new boot replacements are anti-microbial have a smoother surface and are designed to be more resistant to mold issues with proper care. Unfortunately, there are still a lot of the old boot replacements out there. The part number for the upgraded boot is 12002533..., This part number supercedes all prior part numbers for the Neptune boot assy...Hope this helps
Jul 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Washer Odor
Meoser,
I've been selling the only available all natural washing machine and towel mold and mildew remover online at smellywasher.com since 2006.
It's now also available at Ace, Tru Value, Hardware Hank and Do It Best hardware stores. One bottle provides 24 treatments and guarantees to remove mold, mildew, or any odor from your washer. After the washer is cleaned it also safely and easily gets rid of the mildew smell from any towel or clothing that the odor has transferred to.
The dark, moist environment of your clothes washer is the perfect place for mold and bacteria to grow. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change that environment but we can stop the food source for them to grow buy reducing the amount of detergent used and stopping fabric softener use. Go to the blog page at smellywasher.com to read advice on the cause of and cure for washing machine and towel odor.
Nov 06, 2007 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
