Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Runs good for a few minutes then acts like it runs out of gas.
Spits and sputters . Have to prime the carburetor to get it to start. Also while running the motor will start reving up. Any help would be appriciated
  • 636 Answers
Have you checked to see if the fuel filter line has been changed in a while ? If not change this , if you are still having problems could be the float or the jet within the carb
Posted on Jul 25, 2009
Ryobi brushcutter runs good on full tank gas but at a half a tank it starts spitting and sputtering...why
CK for split fuel lines. You can ck when fuel is low by trying to prime with bulb, if you see air bubbles in line , split line in tank.
May 03, 2014 | Cars & Trucks
2005 ultra classic won't run. It will crank but spits and sputters will I give it the gas.
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Oct 11, 2013 | Harley Davidson FLHTCUI Electra Glide...
2002 buick lesabre spits sputters voltage jumps
check you have good earthing points, also check the earthing strap from engine to shell. main earthing point follow the negative lead it will go to the shell.
Jul 26, 2017 | 2002 Buick LeSabre
Spitting gas out of carb with new carb and plugs
could be the coil getting hot and loosing spark
Feb 22, 2013 | Garden
2003 deuce runs bad spits and sputters, hard starting
6. Damaged wire or loose connections at battery terminals especially the negative cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
11. Damaged carburetor or intake seals.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below.
Good luck and have nice day.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 28, 2012 | 2003 Harley Davidson FXSTDI Softail Deuce
My bike spits and sputters and dies as soon as u get on throttle. sometimes will start back up but usually has to sit for awhile. acts like running out of gas or flooding out cause can smell gas. when i...
Hi Mikebecvar, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable especially the negative cable at BOTH ends.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
Harley Davidson Sportster error codes and how to access them
Oct 01, 2010 | 2003 Harley Davidson XL 1200 C Sportster...
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
HOMELITE EXPAND IT 26VT WON'T RUN
Well if you are missing parts?...No. How could anyone from where we sit. But the fact that it starts with starting fluid is a great sign however. First off, Fresh gas/oil mix is A MUST! No getting around that. OK first, when you pull the throttle (Give 'er gas) does the little lever at the carburetor move back and forth at all? if yes, then what happens when you hit the primer bulb? Does it push/**** fuel from the tank? (My homelite spits fuel out to the ground when I prime the bulb, most spit it back to the fuel tank however) See if priming it moves fuel. You should see a trail of bubbles in the fuel tubing. You have to see if you are getting fuel at all first. Then does it maintain the prime? If not? Then the primer bulb will usually remain empty. A good prime should always show a half full or 100% full bulb at all times. Let me know what we got so far.
May 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Mower dies after running for a few minutes
It sounds like the carburetor is running out of fuel.First make sure the tank is full then loosen or remove the gas cap when it starts sputtering to see if that corrects the problem. Then with engine off remove the fuel line that goes from the tank to the fuel pump,hold it low and see if any fuel flows out of it,if not lightly blow air backwards to the tank,(with fuel cap off),then see if the line is plugged. Next remove the fuel line that goes to carburetor from the fuel pump,crank the engine and see if any fuel flows,if so the carburetor should be cleaned by removing it and disassembling it.
Aug 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
272 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
