OS partiton fails,resetup on NEW disc same problem
I have a computer system that has multiple discs.I used Acronis disk director suite 10 to partition and format these discs.My problems is I set up a 72GB primary partition on a 1TB hard drive,the rest I set up as a logical drive.On the primary partition I installed Windows Xp.I set up the OS with all the software I use it was fine for a couple of days then it would spontaneously restart.I tried to do an image backup of the OS using Acronis True Image Home 10, but was told the disc was unreadable because of Bad Sectors.I did a CHKDSK a found many many errors.I thought that the problem was a failing disc so I then set up the OS again using the same Acronis software on another disc.Now I have exactly the same problems occuring.I have no idea what's going on.
    Novelist:
  • 166 Answers
Acronis seems at fault here.its better to keep one partion per harddrive.that way it is't jumping around as many times.use xp to do the partions and see if that works.also make sure *********** board can support the drives terrabyte capacity.also instead of useing the disk defragmenter built in xp use jk defrag it is alot better.you don't even have to install it just unzip and use.can even use off of a flashdrive.if you got any question feel free to email me at gamecrazy944@yahoo.com
Posted on Jul 25, 2009
I formatted the screenplay director hd drive and just have a screen saying :sleeping waiting for usb keys:
ScreenPlay Director Partitions
There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files.
The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection.
The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface.
Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
************************************CAUTION!************************************************ Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
Conclusion: If you have deleted or formatted any of the first 4 partitions on the unit that is not the data partition. You now own a BRICKED ScreenPlay which HAS to be replaced. No if ands or buts about it. YOUR DEVICE IS DEAD.
Dec 19, 2010 | Iomega ScreenPlay
I have accidentally formatted the default partitions
*******************************************CAUTION!*********************************************************
Oct 09, 2010 | Iomega ScreenPlay
I deleted some of the partitions and now the
ScreenPlay Director Partitions There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files. The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection. The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface. Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
*******************************************CAUTION!********************************************************* Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
May 06, 2010 | Iomega ScreenPlay
I have bought a IOmega Screenplay Pro 1 TB. I was able to see some partition in the HD. Accidentally all these partition were removed. So i need to create those partitions and the size details of each...
Feb 22, 2010 | Iomega ScreenPlay
I used this tool to clone my existing 50G laptop drive onto a new Western Digital 320G. Afterward, the rest of the space on the new drive (270G) was gone. I have deleted and recreated partitions on the new...
you need to resize the partition with a partitioning tool like partition magic or acronis disk director, or clone the drive with acronis true image. these tools are downloadable here. That site has a bootable cd, which is loaded before windows starts.
Nov 18, 2009 | Acronis Migrate Easy 7.0 (AME7)
My hard drive is divided into C and D drives, how do I combine into one?
There is only one way to combine into one partition. Reinstall OS, during install delete both partitions and format HDD
Aug 25, 2009 | Acer Computers & Internet
I made a partition using Acronis disk director suite, and i decided to format my dive C, cause i want to have a fresh system again, but i could not access the recovery manager when i press F11 it just...
youll have to install another operating system if you do not have the disks
when you format the c drive you erased the partitions with the recovery, know on many acers
Jul 19, 2009 | HP Pavilion DV6700T Notebook
Can I repartition the drive, and if so, how?
I like Acronis Disc Director for extending partitions. It depends on what drive are you repartitioning. You can use Disk Management if you're not partitioning system partition. In Vista you have an option to extend partition with a free space from other partitions or from unpartitioned space without loosing your data.
Apr 19, 2009 | Computers & Internet
No matter what type of disc I insert, including store bought movies...player says ''does not recognize disc''
Mar 15, 2009 | Televison & Video
I have 3 Hard Disk Drives and my C one is full and the other two are not how do i mack them all one Hard Disk Drives?
"mack them all one Hard Disk Drive"? do you mean make them into one Hard disk drive?
if you have 3 "physical" Hard Disk Drives, im sorry but thats not possible
but if the 3 Hard Disk Drives are only partitioned you could use any partition manager software like Partition Magic or Acronis Disc Director suite to combine the 3 Hard disk partition into one...
hope this helps
^_^
Jun 20, 2008 | Acer Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
