Question about Garden
I can't figure out how the belt goes back on that turns the mower blades
  • 636 Answers
Try this site it is called manuals online
Posted on Jul 25, 2009
Blades won't engage. I hit something, blades quit turning, check belt, its okay. When you hit button to engage blades, you hear click
When you look under the mower do you see two belts ? Top one goes to the rear axle and lower one goes to mower deck spindle.
Your description sounds like the electric clutch is engaging,so if you are seeing two belts coming off the bottom of the engine maybe the belt bounced off a idler pulley on the deck and is not tight enough.
Apr 09, 2016 | Garden
Why are the blades engaged when mower starts and the handle is in off position?
the belt is routed around both blade pulley rear of belt routed to inside of pully tensioner front of belt routed to moter clutch or or in some cercumstance it is totaly the wrong belt and thats what i think your problem is i think you got to short of a belt
Aug 27, 2014 | Garden
How to put a cutting belt on a craftsman RER1000?
cutting or blade belts our not that bad if you follow these two things.Idler pullys that are flat ,the flat side of the belt goes against it. If the pully has a v in the pully ,the v side of the belt goes in the v most times you can figure it out as a lot of mowers out there and the decks are different
May 07, 2014 | Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
How to replace belt on self propelled lawn mower
There is probably a cover on the front part of the mower that goes to the front wheels. remove the cover and you should have access to the belt. Carefully remove the belt (don't pinch your fingers) push it back towards the motor. You might have to remove the blade. Place new belt in the pulley on the engine shaft then to the pulley up front. Carefully start the belt on the front pulley and slowly turn it onto the pulley.
May 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
The main drive belt on my 46'' rider came off and I can't figure out how it goes back on. i bought it used so no manual. The belt looks fine. there is the main drive pulley under the engine, a freewheeling...
best I can do is suggest going to your favorite search engine like google and type in the name of your mower and what it is you need and hit the enter button.. you will be surprised to find what your looking for...good luck
Apr 03, 2010 | Garden
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
Need instructions how to install belt on self propelled craftsman push mower
raise the front of your mower up and support it with something safe like a jack stand
take the blade off
when your blade is off locate the plastic cover covering the belt and remove
now remove the belt but first remove the plastic cover on top of the mower to uncover the gearbox that turns the wheels your belt goes from the engine pulley to the gearbox pulley
you will have to work the belt off the pulley while turning the motor by hand or the same when installing the belt.
to install belt reverse the procedure.
hope this helps some
Jun 06, 2009 | Mtd 22" White Outdoor Self Propelled High...
Poulan mower throwing the belt.
1) Remove the cover on the top of the belt and
remove the belt from the transmission pulley
2) Lean the mower back on its handle and secure it
with whatever you have that will keep it there while
you work on it, any heavy object will do
3) Remove the blade bolt, the blade, the blade
adapter and the plastic belt guard from the bottom
You should now be able to remove the belt
4) While you have the belt off, closely inspect the
pulley on the engine shaft, they sometimes get
grass built up in the groove and this will cause
the belt to run off and also wear prematurely.
Hope this helps you out
Chuck
Mar 15, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
