Question about Sony KV-32FS13 TV
Same problem..kv35s26 Checked the screen control...gently either way. I get picture but a rapid blinking. Also takes 3 to 5 minutes before you hear the "click" when you first turn it on. The screen blinks constantly. Used to blink every now and then but now is much worse. Local TV guy sez that it's the tube and is not worth replacing due to the cost. Any ideas anyone? This thing weighs a ton!
  • 45 Answers
SOURCE: sony kv32s42 trinitron color tv blinking
sounds like a bad picture tube. Picture and bright settings cranked up for a good pic? Test/rejuv with a crt tester and/or look at the Ik signal on the crt board. A good tube has 3 small pulses during blanking. The crt cathodes are checked with these pulses, pulses too low and the jungle IC will blank the drive. If the picture fades in and out I would check the filament ckt but that doesn't support the "blinks"
Posted on Nov 04, 2007
billyjones69
  • 42 Answers
SOURCE: blinks twice pause blinks 4 times
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:billyjones@fletchersite.com
Posted on Jan 28, 2008
SOURCE: 20" Trinitron Wega
Good day.
First, Have your tv 's circuitry be resoldered. this might be a case of loose contacts particularly along the crt circuitry. the longer you operate the unit at this condition, the faster you are counting the possibility of shortening the lifespan of your tube. 9 years is quite a young age for a unit which has an average of 18years.
response is highly appreciated.
chris
Posted on Mar 30, 2008
  • 439 Answers
SOURCE: red light blinking 7 times on Sony Triniton Wega TV
This means one of three things, either the lamp is bad on your tv, the ballast that powers the lamp is bad or the safety switch for the lamp door is not depressed or it has come un-plugged. It could also mean the power supply or fuse on the power board is blown. I am assuming this is a DLP tv, and if so, it is fairly easy to fix it or find parts for it online. If you are slightly mechanically inclined, want to save money and dont mind paying attention to detail then you can fix it yourself. If you need help dont hesitate to ask.
Posted on Jun 21, 2009
  • 8457 Answers
SOURCE: The screen won't turn on. The tv just clicks and
The power board ic coverter it dead.
U need to replace the power board.
U can go the web and buy this board changes
or get the tv repair man replace part and labor $575.
Posted on Aug 13, 2009
My PS3 tries to turn on... but won't
Generally its an overheating Problem send it back to Sony to fix
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
Sony kv35s26 TV: no picture, audio works, stanby light blinks.
First a couple of questions:
1) Does the standby light blink continuously or is there a repeating pattern?
2) If there is a pattern, can you please post the blink count?
With the above information, I should be able to provide you with a couple of possibilities as well as a few tests to perform. Please update this and we'll continue to try and resolve this.
Thanks,
Dan
Jan 19, 2009 | Sony KV-32FS13 TV
Sony trinitron kv35s26 (August 1997) no video, only audio
this is the best out there , but you will have to use one with the same chassi #
http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
glad to help! plz give time for a good rating, thanks , j (electech)
what another models fault is in the video, should help find you find problem
Sony
Model:kv32s45
Chassis:AA2d
No video, Has High voltage. Turning up G2 show a very dim full raster and on the sides a very bluish faint bar .
Replace Vert. IC561 (TDA8172)
Comments:
need any more help just ask , thanks
electech
Oct 29, 2008 | Sony KP-65XBR10W 65" Rear Projection...
POWERING ON
good day
since it is unusual, have it checked by a competent technician. it may only be a simple reset but nevertheless at least you wont be bothered again by that problem
Oct 09, 2008 | Sylvania LC260SS8 26 in. LCD Television
Tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Every several hours the screen goes all blue, and the set turns off.
overheating in back get fans and clean it out dust before it gets worrse
Jan 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is geen and does not stay
Lots of trouble with bad picture tubes on that model! Remove the front grill and very gently tap on the neck of the center picture tube near the socket with the back of your screw driver. If the picture flashes back to normal that means the the tube has an internal short. You may hear a snapping noise while tapping and the set may shut off. If the tube is not sensetive to tapping it it possible you have some other type of failure.
Nov 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony kv32s42 trinitron color tv blinking
Oct 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS13 TV Logo
130 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
