Question about HP Pavilion zd8000 Notebook
Hp Laptop screen flicker
Not exactly flicker. The screen on by HP pavilion goes black. Sometimes it can be "reactivated" by quickly punching the "lid close button". It does not seam to be any kind of physical bad connection that can be affected by moving the lid, tapping the notebook, or hitting it with a sledge hammer, etc. When the room lighting is right, the screen image can be seen, indicating that it is a back-light issue. Sometimes it does flicker and seems to coordinate with the hard drive light flicker. This has been a problem for two years or more. Fred
  • 2 more comments
  • moorera Dec 04, 2007
    Yes, I'm having the same issue. Seems to be no rationale as to what's causing it. Last time, I just connected my external monitor to the laptop and that seemed to trigger the laptop backlite to work again. I agree, it appears to be the backlite issue and mine does flicker.
  • Anonymous Mar 13, 2008
    screen back light problem, works when plugged to external monitor
  • Em25291 May 20, 2008
    Mine does exactly the same thing!
    I just have to switch it off and try again, usually i can just keep tilting the screen backwards and forwards. If its nearly closed the screens fine, but as soon as i open the screen it starts flickering and in the end goes black completely. Its def as if the back light goes out!
    I work in a audio, tv and computer department in john lewis and we've had a few complaints about this.
    Its so frustrating!
  • JCiwjS May 11, 2010
    zd8000 replaced system board that took care of checkerboard problem, replaced lcd inverter and flickering screen problem went away temporarily and is now back. I can change resolution like before and flicker goes away but always comes back. Only affects right side of screen. Ideas?
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Posted on Aug 10, 2009
    New Friend:
I am having the same problem on a pc. HP Pheonix and Hp 2311x monitor
Posted on Nov 10, 2012
  • 324 Answers
Good afternoon,
Got 2" of snow today. Oh, well! Spring is only 5 months away.
My suggestions, from least to most probable are:
1-LCD display cable, loose or damaged.
2-Lid close button, may be loose or bad.
3-LCD lamp.
4-LCD lamp inverter, connector loose or bad board.
Did this info help?
Posted on Nov 21, 2007
2 Suggested Answers
  • 186 Answers
SOURCE: hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Posted on Dec 06, 2008
HP Pavilion dv6 7040 TX Laptop screen on right hand upper corner turns dim and after some time becomes uniform
Being a led screen maybe one or more of them have gone bad
Or if you are lucky just a faulty lcd ribbon cable
Mar 25, 2014 | Computers & Internet
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ... › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
Screen goes black and when tuned off for a while will come back on and sometimes flickers like it has a bad connection. It is a hp pavilion f 1703
bmiller013, Problem been around for some time!!! Surf over to this blog and do some reading first. Then you can come back to this posting and rate it if it helped you find out why your monitor has crapped out on you. Good luck with the repair guy. 12fixlouie
Mar 11, 2010 | HP Pavilion F1703 17" LCD Monitor
Video problem. Pavilion ZE4805US laptop
Most likely it is either a bad lcd inverter, due to the fact that you have clear picture on an external monitor. The inverter reduces the voltage coming from the motherboard to a lower level in order to power the lcd and the backlight. If this goes bad then you either get a picture randomly, a dim picture, or no picture on the lcd.
Feb 05, 2010 | HP Pavilion Ze4805us Notebook
HP Pavilion dv9700 black after closing lid.
when you changed it to do nothing on battery or power did you save these settings........I know it is a silly question but it sounds like the laptop is going into Hibernate mode
Jul 31, 2009 | HP Pavilion dv9700t Notebook PC
Locks screen when I close the lid on my hp pavilion dv9740us
computer has gone into hibernation. Best to shut that function off, and replace with standby.
If you want it to hibernate, press the power button once, and it should come back on to the log in screen.
Mar 14, 2009 | HP Pavilion DV9740US Laptop
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Screen flickers
It is either the inverter board or the backlight. There are no fixes, only replacement.
Nov 10, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
10,134 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
