Water drains from the bottom of the washer not drainhose
Water drains from the bottom of the washer not out the drain hose, why? What could be the problem?
  • 1 more comment
  • sternla Jul 26, 2009
    TheMobilian,
    The washer is a Kenmore 70 Series, model 110 24722300. I hope this helps in your diagnosis of the problem.
    Thnaks,
    Sternla
    TheMobilian,
    Thnaks,
    Sternla
  • Dan Webster
    Dan Webster May 11, 2010
    The number one cause is a leaky water pump seal. The second most frequent cause is the tub to pump flex hose. Older washers will tend to have seal leaks. Sometimes trash gets in the water level hose and that would cause a flash flood. You know what: I have repaired a lot of washers with leaks. If you were to give me a model and make I could just about tell you spot on what was causing the leak. This is not an answer, this is a request for more info.
  • Washing Mach... Master
  • 8,220 Answers
I think it may be the hose from the pump to the rear drain connection. Take a look at these repair PIX
Posted on Jul 27, 2009
Testimonial: "TheMobilian......THANKS for your help. Hoses were not cracked or leaking. When I took the pump off it was cracked. I replaced it, & no more leaks."
    Novelist:
  • 108 Answers
Well, it could just be that the drain hose is cracked, or it could be something more serious.
Removing the cabin to see inside is pretty easy, but it varies depending on what kind of machine you have.
Posted on Jul 25, 2009
Testimonial: "The hoses were not cracked, it turned out ot be the pump was cracked. I replaced it and no more leaks!"
    Problem Solver:
  • 7 Answers
I would say one of the valves on the pipe is loose
plumbers could fix the problem
  • Jake Stax Jul 25, 2009
    i would say one of the valves on the pipe is loose
Clothes coming out vwey wet on all washes
Check drain inm back of washer. Do not move the washer because the drain will straighten
out and you will never know if that was the problem. Look behind washer with flashlight.
Also pick up the drainhose out of washer drain pipe and watch the volume of water when its
pumping. If its restricted the cycle will end before all the water is pumped out.
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Washing Machines
During the water supply in the tub, the water gets drained through the drainhose. New Machine one day old. What causes that drainage. Top Loader LG machine. Model: WFT11G00TED Water keep on draining...
The problem is the drain hose is to low or to tight in the standpipe. The standpipe is your home plumbing. If it does not have an air gap around it, it will create a siphon effect. Here is a link with more info http://appliancehelponline.com/washerdrainsfills.html
Jul 29, 2010 | LG WFT1071TP Top Load Washer
My tromm frontload washer is not draining. I
in order to check the main drai hose the whole front panel needs to come come off.This is done by removing the lid.
then remove the screws that hold the main control board, then you need to remove the rubber boot from the front panel.then remove the screws that hold the front panel on the machine.
Feb 22, 2010 | LG WM1814CW Front Load Washer
Kenmore series 90 washer keeps filling with water and won't stop during to move on to next cycle
If overfills onto the floor , then the waterlevel switch hose came off the switch behind the control panel . You have to remove the 2 side screws and tilt panel to see the hose and switch . If the water keeps filling , but doesn't go on the floor , then you have a syphon problem at your drain . As it fills , water is being sucked out by your drain due to no air able to get in around the drainhose and drainpipe . Pull drain hose out of drain and only insert about 4-5 inches into drain . If hose is tightly in drain , a parts house or home depot should have a syphon break in stock .
Jul 22, 2009 | Kenmore 22422 Top Load Washer
Kitchenaid KUD101FLSS3 Won't Drain
did you take the knock-out from the garbage disposal. It is located in the line where the drainhose is connected.
Mar 15, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
My Whirlpool Ultimate Care II will not fill up with water.
ck drain hose end of hose should be at least 30-36 inches from floor also end of hose needs to fit loosely in standpipe ..if drainhose is too tight siphoning will occur
Dec 21, 2008 | Whirlpool Ultimate Care II GSW9650LW Top...
NOT DRAINING
means your pump is blocked. Apperently there is no main filter according to the book .
It means you will have to open the machine and disconnect the hose from the pump and clean the pump. ( i presume the pump works?)
make sure you try to drain as much of the water by putting the drainhose low into a bucket or basin.
let me know what happened
Jun 24, 2008 | GE WSXH208A Front Load Washer
My teka dishwasher does not drain properly and there is water left in the bottom after the cycle has finished
Means that your pump is obstructed. Clean the filters out and if tha does not work clean your pump and drainhose.
That will solve your problem
May 01, 2008 | Dishwashers
Washer issues
that doesnt sound right at all, no questioning you, your seeing it happen but as a whirlpool tech for MANY years thats not a normal complaint.
i assume its a top loading washer.
besides this issue have you had other problems????
did you replace pump??? reason i ask is perhaps you switched the pump outlet and inlet hoses( some models they are actually same size)
assuming they are in the respective openings, cant really see a reason as to why it would POP off unless theres a magor back pressure issue, have you checked the drainhose itself and looked for a possible blockage??
thats a pretty hardcore spring style cl;amp holding that on. make sure it pushed allthe way to the throat of pump assy
Apr 02, 2008 | Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
