Question about GE Washing Machines
GE Top loading normal (not HE) washer. Will not fill with cold water - when set on cold, nothing comes out. When set on warm, or hot, hot water comes out. Cold water will come out for rinse cycle. Had problem yesterday, then this morning was able to wash one load in cold. Since then, have had to wash all in hot. Checked to make sure cold is turned on, but cannot find any other normal things to check. Any help would be HUGELY appreciated!
  • tonilyn18 Jul 26, 2009
    Ok - tried that - screens are clear. But, while I had the water turned off, I checked to see if it would come on. When it was on warm or hot, it hummed, like it wanted to fill up (water off). But when the cold was on, there was no hum, so I assume there is an electrical issue. Is there only one specific part it could be, or are there several components that could be the culprit? Thanks for the help! For the time being, I tricked the washer and switched the hoses so I can set it to hot and have cold water! LOL...redneck ingenuity...LOL Thanks again
  • GE Master
  • 8,220 Answers
Shut off the water and remove the hoses, check the inlet screens. Look at the repair pictures HERE
Posted on Jul 25, 2009
  • Dan Webster
    Dan Webster Jul 26, 2009
    The solenoid is bad on the cold side.
When washer fills on warm water mode, it alternates between cold and hot water coming out in spurts. Is this normal, as it doesnt do it on rinse cycle.
yes its normal the reason it does not do it on rinse is that only cold water is used to rinse not /hot warm
please rank this advice if it helped
thank you
Dec 28, 2010 | Maytag MAT13MN Top Load Washer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Jul 19, 2009 | GE WJSR2070B Top Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Oct 26, 2008 | GE WBSE2090A Top Load Washer
GE washer
if you are only getting hot water on warm setting possible bad inlet valve cold side ck wiring first just to be sure wire to cold side not loose
Jun 08, 2008 | GE WHRE5260E Top Load Washer
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
