SOURCE: setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button
2. Then dial ** (star, star)
3. Enter the password (usually 1234)
4. Press 'Next' until you get to 'Ext Name'
5. Press 'Enter'
6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is)
7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters.
8. Press 'Enter' then you are all done... pick and hang up the handset.
SOURCE: How do I change the language on my panasonic kx-t7630
Press the left button under the display (PROG in English) dial 021 STORE (4th soft key).
Now the buttons say PROG :-)
Carl
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
