Question about Delphi Roady XT XM Radio Receiver
Will not turn backon
I had just signed up for xm and the skyfi3 was working fine I disconected it to connect the antenna and it would not start! Is there any one close to seattle I could take it to for repair?
  • Delphi Expert
  • 509 Answers
Call Delphi's 800 number and if it's under warranty they will exchange it for a refurbished unit.
Posted on Aug 24, 2009
When using headset with skyfy3 display says check antenna .
Are you using the special Delphi headphone with the built=in antenna? There is NO antenna built into the SkyFi3 like the MyFi - you must have the special headphones with the antenna built in. okay?
Jan 18, 2011 | Delphi SKYFi3 XM Radio Receiver
My skyfi 3 keeps displaying no signal and antenae is in the clear? Any recommendation. Ive updated firmware.
Your dock connector has a cold solder. Resolder the antenna pins to the board. The antenna pins are the 1 n-shaped pin (connects to 2 pads) with 1 pin in the middle. Resolder your middle pin.
Dec 26, 2010 | Delphi SKYFi3 XM Radio Receiver
I have a XM delphi skyfi3 and I can record songs and listen to the radio portion fine. However, I cannot play my recorded music back on the my music mode, regardless of whether the xm is in the cradle or...
You must have a subscription and listen 'live' 8 hours a month, or it doesn't let you listen to recorded content anymore (thanks to the RIAA and their royalty fees to XM)
Jun 27, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
Skyfi3 stuck in Detecting SD Card mode - tried popping SD card in and out a few times - that didn't work. Tried pressing the Mode button and the volume plus and nothing. Tried to XM Firmware Update and...
8GB card is a SDHC card, and these units were designed to read SD cards. At a glance, you would think it shouldn't make a difference, but data is stored differently on SDHC because of expanded capacity than SD cards. I, too, learned the hard way; purchased storage card before researching "processing" capabilities of the Skyfi3 units.
Your card should work fine in a Cell phone or other devices specifically designed for SDHC cards. Hope you get some use out of it.
Feb 18, 2010 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
XM receiver starts up and then shuts down
I had a similar problem with a portable XM radio. The antenna, connection and cableall looked fine, however, the centre conductor of the antenna lead was damaged where the lead went through the door jamb. Look for any type of crimp in the antenna cable and if so, either get someone to repair the lead, or get a replacement antenna.
Apr 28, 2009 | Car Audio & Video
My xm skyfi3 is on and the buttons will not work It is frozen up and I cannot get it to turn off or do anything. I have checked the button lock switch and it is off
Try this: "Reset your SKYFi3 by pressing and holding the volume button and pressing the mode button" (from user guide page 62)
Dec 13, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
140 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
