Question about JVC KD-S6060 CD Player
Car radio Code
Hi there
I had to disconnect my battery of my car the other day and unfortunatly dont have the code for my radio as its a second hand car. How do i get this code to get my radio working?
My radio is a JVC KD-S6060.
Please could you help me with this.
Thank You
  • 113 Answers
Re: Car radio Code
The code for this radio was not set by the factory, but by the original owner and the code could be anything-unfortunately unless you contact the original owner and they know the code you are out of luck
Posted on Mar 22, 2008
0 characters
3 Points
Need code for sony cdx-l480x eq3 stereo
There is no code for resetting a radio. If there is not reset switch, you can reset a radio by disconnecting power to it for a few seconds. This can be done by either disconnecting the wire harness behind the radio, or if you don't know how to get the radio out of the dash, you can disconnect one of the terminals of the battery for a few seconds.
Oct 02, 2012 | Sony Car Audio Receivers
Hi all....I've got a 2001 Fiat Punto, and after disconnecting the battery the radio is asking me for code. When I turn on the radio, it says
Most car radios need a code when theyve been disconnected , also some car radios are made to turn off after 20 mins use so that it cant be left on accidently , this is a battery saving idea , it can be bypassed though by rewiring a live connection to the radio rather than a connection through the ignition
Sep 23, 2012 | Car Audio Receivers
Hi is there a default radio code for nissan primastar 2007???
No their isnt a default radio code but this is a 2007 and it was about this time that manufacturers started using radios that worked via the ECU so if a battery was changed it didnt lose its code ,but yours could be of the older type and need a code so if you bought it second hand and didnt get the code number then ask at dealers but if it was a rental car in its first owner then its possible its 1111 as i know all our rental cars came like this with code reset so us at the airport couild reset the radio if the customer left the lights on or whatever
Mar 04, 2011 | Car Audio Receivers
I disconnected my car battery and my radio says to enter code dont no it bought the truck with the radio in it
try to call the vendor on the radio. most of the time they will have a master reset code
Aug 25, 2010 | Kenwood KDC-MP242
93 honda accord - The Battery was disconnected
Hi; I do not believe the need the s/n from the radio. If you can contact the dealer where you baught the car new, they will have the code in their sevice department records. Just tell them the VIN for the car and they should give it to you free. When you get it it is 5 digits in length. Press and hold the code button untill you here a beep. Release the 'code' ( the am/fm ) button and enter the code numbers using the preset buttons as the numbers (1-5or else 6).
Don'let them charge you for giving you the code.
Dec 18, 2009 | Car Audio Receivers
How do I get the code number for my radio in my 2001 Boxster S? Card lost and battery was once disconnected.
You should be able to enter the 4 digit code via the radio. Ifthe radio has been replaced, you may need to recover the radio'sserial number: Porsche Boxster: Online Lost Radio Code Recovery Tool
Aug 11, 2009 | Car Audio Receivers
Car Radio
I have the same head unit and disconnected from the battery. There was no input code required when reconnecting the battery You should be ok! I can't help with your Tuner problem though! Good Luck!
Aug 20, 2008 | Sony CDX-L580X CD Player
Car radio Code
You will probably have to contact the manufacturer and speak to a technician to get the factory reset code. Chances are, the code was put in by the previous owner of the car. When this code is entered, it makes it impossible for the unit to operate if stolen. Hope this helps...
May 17, 2008 | Pioneer DEH-1900MP CD Player
Car radio code
ok i dont know if this helps but i looked up some info on getting your radio code back
i dont know the codes off hand but this is what general consences says
"if you look on the right hand side of the radio, you will see a four digit code beginning with a letter. it is usually located near a bar code, and sometimes it says the word 'security' by it."
also Renault dealer can find out the code for that radio.
i copied and pasted this from a friend from the sterio installation bay at best buy
hope this infor helped
May 01, 2008 | Car Audio Receivers
VT Commodore security coded head units
Call Holden with the VIN# on the car, and they will give you the correct code.
Mar 10, 2008 | Car Audio Receivers
JVC KD-S6060 CD Player Logo
231 people viewed this question
Top JVC Car Audio Receivers Experts
xxxxxx xxx
Are you a JVC Car Audio Receiver Expert? Answer questions, earn points and help others
