Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Will not run unless you pour gas in the carborator
Also check to make sure your fuel line isn't broken or kinked.
Watch the clear fuel line to see if fuel is being pulled toward the carb. If the fuel line is not restricted and the carb stihl won't pull fuel,... you'll probably need a carb kit.
The fuel pump side of the carb isn't pulling fuel. the little check valve flaps are probably pulling away from the holes and no longer sealing..
Craig
Posted on Nov 26, 2009
  • 636 Answers
Check your gas tank inline fuel filter
Posted on Jul 25, 2009
What would make a not start unless I pour gas into intake
Hi Clyde:
Since you mention "gas rail" I'm assuming fuel injected.
I'd check the fuel pressure in the rail. Should be around 40 PSI.
If pressure is OK then injectors not working. Time to check cps.
You know the spark side is OK since it will run.
Nov 08, 2015 | Cars & Trucks
McColloch 7800 generator leaking fuel from the carborator.
rebuild carb using new needle and float if float is full of gas and sinking
Sep 17, 2012 | McCulloch 13HP 338 Cc Portable Generator #...
I have an 88 ford broncco 2 eddie bower edition and i have replaved both fuel pumps and it still wont start unless you pour gas into the carborator then when the gas in the carborator runs out it dies
you may have a gold coloured filter that screws into your carb. Unscrew it and check to see if you can blow through it. It may be clogged. Also you can check for fuel at carb by loosening the fuel line going into the carb. Crank engine after loose. Should have gas coming from it.
Oct 20, 2009 | 1988 Ford Bronco II
My jeep will not start all of a sudden. When gas
Check the fuel filter, and i would suggest replaceing the fuel in the tank. It only takes about a month for gas to start to deterioate and if it sat that ling there is probally some junk in the tank. witch probally caused the fuel filter to plug up.
Jul 21, 2009 | 1985 Jeep CJ7
Fuel
the fuel filter sounds like the problem, are you sure its carborated not fuel injucted because fuel injuction has a regulater for the fuel if it is stuck open you would pump gas to the fuel rail and back to the fuel tank
Dec 23, 2008 | 2000 Oldsmobile Bravada
Car won't run
you need a new fuel pump
Oct 18, 2008 | 1989 Nissan Sentra 4 Door
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
274 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
