Question about Dacor DMT2420 1200 Watts Microwave Oven
The micro wave heats but won't pop popcorn. We do more time than required but 50 - 70 % OF THE KERNELS DON'T POP.
How old is your popcorn? If it's over a year old in the pantry and not in the fridge it tends to dry out/shrible inside. Or...note that these days instructions indicate between 2 types:
regular hot air popping method and microwave friendly popcorn. You can buy hot air poppers cheaply at many resale shops.
Posted on Jul 25, 2009
When I microwave small bag of Orville Redenbachers popcorn almost a third of the kernels do not pop and popcorn burns.
Be sure to place the bag with the proper side down on top of an upside-down paper plate, and put it off-center, not in the middle of the turntable.
Jan 16, 2014 | Sunbeam Microwave, 0.9 Cu.ft - Black
I tried one cup of water with my bag of orville redenbacher mini popcorn bag. it did not pop at all. the cup and the water were hot, however in microwave. help
follow this steps and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Oct 24, 2013 | Sharp R-1870 Convection/Microwave Oven
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Magic Chef MCD1611W
Popcorn popper 50030178 I found this old popper like my nanny used to use. But I don't know how much popcorn or oil to use can you help me. I have the measuring cup lid all the parts with it.
What type of popper is it? The 50030178 model isn't one I'm familiar with.
For most of the small air poppers, such as the Presto Air poppers, fill the measuring cup lid with popcorn so that the popcorn is level with the top of the cup. Add this amount of popcorn to the popper. On those units, there is a fill line inside the popping chamber. Do not fill past the line. For these air poppers, if you want to have butter or margarine on the popcorn, add 3 tablespoons of the extra to the lid after you replace it on the popper.
For the Hamilton Beach Hot Oil Poppers, the manual for the 73300 is available here: http://www.hamiltonbeach.com/use-and-care/use-and-care.php . Fill in the type of device and then the model. The amount of oil and popcorn will depend on how much you want to make. For a single serving, you need 2 T (tablespoons) of kernels and 1 - 1 1/2 t (teaspoon) of oil. For enough popcorn for a family, you should use 1/2 cup of kernels and 1T of oil. http://useandcares.hamiltonbeach.com/files/840190701.pdf has a full chart of the amounts on page 6.
I hope this helps. Please add a comment with the brand of popper and I'll check for a specific chart for that unit.
(It's been a while since I used the air popper that I used to have.)
Jun 21, 2011 | Hamilton Beach Microwave Ovens
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
What should my powerlevel be on on my microwave because it keeps burning my popcorn
Your power level should be on high, but you shouldn't rely on the oven to time the cooking. I have yet to find an oven that won't burn popcorn if it has a preset POPCORN button. Press it and walk away and next thing you know, you've got charcoal. You should always stick around while making popcorn. Stop the oven and take the bag out when the time between pops drops to 1 or 2 seconds. The corn will continue to pop on its own for a bit because of stored heat, but you won't burn it. You'll never get 100% of the corn to pop, so don't worry about unpopped kernels.
Feb 28, 2011 | Emerson MW8777W Microwave Oven
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
Dec 29, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
No heat
If you remove the outer cover of the microwave, you will see a magnatron. Usually on the RHSide of the micro. This magnatron will need replacing. On the magnatron,is an over temp.sensor. If this gets hot excessively, then all will stop untill it cools down. This indicates magnatron is faulty.(Assuming cooling fan runs when micro program is selected and switched on). Honestly, i would suggest caution if undergoing this repair as the voltages are extreemly high and there are proceedures to repair theese units. Testing equiptment a must.
Sep 14, 2009 | GE Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
382 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
