Question about Garden
The oil in my Honda leaks
It is coming from the edges of the top of the engine the oil leak on comes on when started
  • 67 Answers
Sounds like the upper crank seal is leaking underneath the flywheel
Posted on Sep 02, 2009
Hello I have 1997 gmc jimmy 4x4 , I just 4 days go private sale but notice a oil leak underneath cannot tell where it's coming out from sum where up high from underneath motor
possible a rocker cover gasket that needs replacing
run your fingers around the edge and any wet oil indicates the leak
could also be oil that was splashed on the cover during an engine top up or oil change
Aug 12, 2016 | GMC Cars & Trucks
Honda fourtrax 350
Hi, if there is smoke 10-20 minutes that is fine, probably just residual oil from the top engine work.
if the smoke is a hour coming off the engine because of external oil leak, sounds like head gasket is leaking. If you continue to run the machine like this, make sure to always check oil levels and add oil when low. As long as your smoke is not coming out the tail pipe which would mean you are burning oil and would need to be fixed.
side note: Its always good to have a Haynes manual for any machine you own, they have great troubleshooting tips.
Honda ATV Repair Manuals Do It Youself DIY Manual to Repair Honda...
Sep 06, 2014 | ATVs
Oil leak at bottom of timming belt cover
what engine.? lots of engines, used. and 21 models of civic, USA.
its usually.
1: valve cover, (yes, most can leak from top down behind the belt.
2: cam seals
3: crank end seal
4: oil pump seals.
6: oil pan ( last choice)
finding oil leaks takes hard work , clean, it find it .
or use the dye kits.
gravity and wind, allows it to go where ever IT wants.
so it must be clean first to find it.. see?
or use the dye kits, it shows a live leak best.
ever look here?
http://estore.honda.com/honda/parts/view-honda-parts-catalog-detail.asp?m=1997-civic-2-dx-4at&sn=&b=E++09&dl=
question, at the 60k mile service points. you check lash, settings.
with a new timing belt. and at such point, a new valve cover gasket gets fitted, did you? if yes, its not leaking if not>????
the front edge of the VC gasket, leaks down behind what i call
the VC leak hidder, tin pan. plate. behind the cam cog
is a plate, and the VC leaks down from there to the cam seal
then down front of engine, then past crank seal the, to cover.
seen this on all most all OHC engines...
cause, nobody does the 60k or does it and uses the old gaskets.
id look there first. but id dont have service history.
start high work down due to gravity.....
the FSM is here.
see that too. "free" too
http://hondatech.info/downloads/Auto/Manuals/Civic/
Dec 17, 2013 | 1997 Honda Civic
Screeching noise coming from engine...HELP!!!
No probably what your hearing is the belts slipping, they are probably getting oil on them from your leak and slipping.
Nov 16, 2009 | 1992 Honda Accord
Oil in my honda civic 1991 is dripping all over but only when the car is running any ideas?
your the only one that can answer where, check the oil filter and the oil light switch first.
Oct 02, 2009 | Honda Civic Cars & Trucks
My 1992 isuzu trooper is leaking oil .it appears to be coming from top passenger corner of oil pan.however oil has coated parts to rear and above oil pan.oil leak is slow.could this be oil pump.what are...
clean your engine and look very carefully where the oil leak really come from, the cause why this leak happen, the engine was shutdown while the engine temperature is hot. usually the leak will come from the turbo. the engine must be idle for 3-5min before shutting off.
Jun 30, 2009 | 1992 Isuzu Trooper
Oil leakage
hi from uk if your oil ? leak is from rear of engine area ? but you say oil level in engine is ok? and not needed to top up ? then i would check the gearbox/transmission oil level? for any loss? asap it may be your leak is coming from g/box/transmission front seal ? but either way gearbox will have to come out do be able to replace both rear engine crank seal and g/box front seal at the same time ? hope this helps you don;t delay in topping oil level in trans ?
Nov 11, 2008 | 2005 Honda Pilot
Garden Logo
395 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
