Question about Infinity Reference 1211a Car Audio Amplifier
Its not a aftermarket amp it is factory - Infinity Reference 1211a Car Audio Amplifier
  • 4,234 Answers
Diagrams for these units are not available even to the service centers. These are factory replacement only for warranty. The designs are straightforward though. Can you describe the problem? Perhaps we can privide enough information to enable you to repair the unit.
Dan
Posted on Jul 25, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Do u have to bypass the factory amp to use a aftermarket head unit in a 2004 gmc envoy stanard system
If you do not have access to an aftermarket interface cable (some are available depending on brand and model of aftermarket radio), then yes, you have to bypass the amp if the new head unit has an internal amp, AND you wish to use the factory speakers with the new stereo.
There are many ways to do this, but if you want to do it yourself, the absolute best way is to get a copy of the dash harness wiring diagram from GM. This diagram will identify which pins in the radio dash harness connector run to the speakers and/or the amp, and whether you have to run new wires to the output side of the amp to connect to the speakers--this will not be specifically identified in the GM diagram (it will not say anything like 'to connect aftermarket radio, etc.), but it will be evident that you have to do this if there are no speaker pins in the in-dash connector.
May 21, 2014 | 2004 GMC Envoy
Radio reads amp error
what radio? factory, aftermarket, etc? if its factory just go to a wrecker for another one, yours is non-repairable. Aftermarket is a problem for a stereo guy.
Mar 18, 2014 | 2000 Dodge Stratus
Aftermarket amp in a 2011 bmw not getting power
replace the fuse and make sure that your remote turn on lead has not become disconnected.
Mar 06, 2014 | JVC Car Audio & Video
After a after marker radio install I have no sound from my speakers. 2000 eclipse
I can definitely solve your issue. I just need to know a few things.
1.) Was the factory amp used in the install of your aftermarket deck?
*if equipped the amp would be located underneath the passenger side seat*
2.) Did you use a cable harness to connect to the factory harness when you installed the aftermarket deck?
Jan 29, 2012 | Kenwood Car Audio & Video
I have a Kenwood 6140 installed in my Corvette Coupe. I have everything installed but the sound doesn't sound right. It lacks something and I'm thinking that the subs aren't on! Could this be my problem...
Normally if you have a factory ampped system and you remove the factory headunit you lose things like the factory sub. There are only 4 outputs on an aftermarket sub. In order to make your subs work you will need an aftermarket amp.
Nov 17, 2010 | Kenwood DDX514 Car DVD Player
I'm installing an aftermarket audio system in a chevy silverado using 2 amps. how would i get sound to the factory speakers from an aftermarket amp?
The best way would be to run the wires from each amp straight to each speaker. Just be careful with the amps. Most amps for full range mode are set for 4 ohm speakers. In a silverado they will probably be a lot less which could cause a short in the amp. Good Luck.
Aug 17, 2010 | Car Audio & Video
I jumped my car with jumper cables and now the radio does not work
Is it a factory or aftermarket radio? In any case you'll want to check your radio fuses. On aftermarkets there is typically a ten amp fuse bhind the deck and your owners manual will tell you where your factory fuse box is.
Oct 08, 2009 | Volkswagen Car Audio & Video
My 00 dodge avengers new cd player is not working with my system
There should be a wire in the factory harness that turns on the infinity amps. If you used an aftermarket adaptor harness it should have a blue or a blue white wire in it, or both. When this wire, or wires receive 12V, the factory amp will turn on. this will need to be hooked to the aftermarket stereos blue wire.
Aug 18, 2009 | Car Audio & Video
Infinity Reference 1211a Car Audio Amplifier Logo
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
