Question about GE GSS25JFM Side by Side Refrigerator
I have a GE model# GSH25JFXJ that I have had for around 3 months and have only been able to use it for a total of about a week. The freezer works ok but the fridge side keeps getting warmer even all the way up on 9. The repair man has been here 6 times and has added freon, let freon out, and replaced the computer board and it is still acting up. I need to no what the steps are to adding freon to the refrigerator cause I don't think he did it right. Don't you have to vacuum the system down once its been opened? and how much froen should be in it? Thanks, Debbie
  • 1,543 Answers
1. If you are cutting the system open, like installing a new compressor, repairing a leak, or install a new filter drier, yes, the system would be pumped into a vacuum, but just to add refrigerant, no you can add some without pumping the system into a vacuum.
2. If the freezer side works, the sealed system should be fine. On most refrigerators, all the cooling takes place in the freezer, and the fan in the freezer blows some of that air into the refrigerator section to cool it. It sounds as if you have an air flow issue. I would check the air dampner at the very top back left side of the refrigerator section to see if it is stuck in the closed position, preventing air from entering the fresh foods section. (air exits back out the bottom left back into the freezer compartment)
3. If this unit is indeed under one year old, call GE to request they dispatch a different service tech to assess the situatiion. Try 1-800-386-1215.
4. Oh, almost forgot. The proper factory charge of refrigerant in the system is listed on the model / serial number tag. It will be listed as something like 3.2 or 4.15 Oz (or similar amount) of R-134A. Once extra refrigerant is added or removed, the only way to get an acurate charge is to evacuate the entire system (into a vacuum) and re-charge it with the exact amount of refrigerant.
Posted on Jul 25, 2009
Why did fridge stop working, then freezer 4 days later?
how it works. 6 month ago another technician came to this service call and found out that system is low on freon. So he charge it up with freon and add leak dye into the system. Leak was really slow, so he could not find at first. Here Im 6 month later, found leak dye with special light (dye leak set (tools) cost about 180$), did not need to order any parts, but replaced copper tube. Customer paid around 600$ for repair total for this repair. Hope That Helps!
Aug 16, 2015 | GE GDS18LBR Bottom Freezer Refrigerator
Freezer fine, fridge not cooling
This sounds like a small Freon leak. It could come from cleaning the coils, or movement by the compressor. A technician with a gas tester (locator) can find any small leaks and repair that section. The cost is not excessive and a new unit is over $1000, so consider the options.
Mar 10, 2014 | GE GTS22WCP Top Freezer Refrigerator
I have a 20 cf upright GE freezer that isn't
it may be froze up, and require a defrosting. use a portable fan to speed up this process , also make sure the fan in the freezer compartment is working, with a little work and a zoom spout oiler, or some light motor oil, the motor can be sparked back to life.. freeze ups are common with the high humidity we are having these days.. jay the pool pump motor repair guy longwood Florida
Aug 02, 2011 | GE Freezers
3 year old side by side hotpoint. 3 months ago freezer frosted up & would not cool. Repair person replaced heater & mother board worked until about 1 month ago. Frosted up again. Repair person...
This is the part that is bad....it is cutting off the defrost too soon...
http://www.partselect.com/PS1017716-GE-WR50X10068-Defrost-Thermostat.htm?SourceCode=5&ModelNum=hss25gft
or Click here
heatman101
Aug 02, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Freezer is icing up on back wall and not keeping food frozen
what is the model i beleave the techincan did not change the defrost thermostart
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile TCC18 Refridgerator freezes Up regularly.
I had the same problem. I changed the defrost thermostat and that has solved the problem. Just to make sure the problem is not recurring I drilled a small hole in the back of the plastic drain(behind the fridge) so that I can put a long screw driver inside to determine if there is any ice build up. None so far after 3 weeks.
Feb 28, 2009 | GE GBS22HCP Bottom Freezer Refrigerator
The freezer is freezing up every 3-4 weeks
likewise, sorry no solution but have the same problem. freezer develops ice build up and also stops fans from going. solution would be welcome - tried defrsting and yes works but oly for a while.
Jan 21, 2009 | GE GSH22JFT Side by Side Refrigerator
GE GSS25JFM Side by Side Refrigerator Logo
285 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
