Question about GE Security Simon 3 Wireless Home Security System
I replaced back-up battery in my GE simon 3 ( 4 hrs ago), however when I perform a system status check I still get the msg "low battery".
You must unplug the transformer to the system before installing the new battery so the system recognizes that the battery is in place. Once you have installed the battery it is safe to plug the transformer back in.
Posted on Aug 29, 2009
The low battery alarm is sounding for both the console, AND the remote - which I do not have. The ADT people can't come out for another week. How do I silence the beeping? I turned off the status beeps...
The Simon 3 supervises the panel battery and when it's bad or the a/c has been out for a long time..will likely have to charge the battery. A problem arises where the keypad unit will not acknowledge that the battery has been recharged/replaced without you doing a basic power cycle.
Whenever this panel battery is replaced in a Simon 3 (worn out or depleted from no A/C (power-outage)) you should disconnect the A/C adapter, install the new or recharged battery properly and hear the panel tell you it's ok..."..simon ???? is OK.." and THEN plug in the A/c adapter. Assuming the panel is not damaged..it will talk when a suitable battery is installed with the A/c out. If it doesn't talk..check the battery with a test meter. Voltage over 6 volts(approx) is required to make it talk.
Of course, after a total power cycle you will have to set the clock.
Remotes(key fobs) aren't usually supervised (as they are carried away from the site) so it's unlikely it's referring to a key fob low battery. Might you be talking about a remote keypad or device in another part of the house or garage that may have low batteries..finding it and checking the batteries will clear the second part of your beeping.
Aug 23, 2011 | GE Security Simon 3 Wireless Home Security...
I have a Simon XT which I installed about two weeks ago. I keep getting a system low battery message when I press the status button on the console. I had a new battery shipped and I installed it about 24...
Call your Central Station and put your account on test if it is a monitored system.
Power down the system. Disconnect the battery, then the AC adapter. Then plug the battery in first, then the AC adapter. Plugging the AC adapter in first can cause the low battery message.
if that doesn't work, with the battery disconnected, measure the voltage of the battery with a multimeter. If it reads less than 5.4 volts, the battery is bad. Bad out of the box batteries are not too uncommon.
Next, check the charging voltage from the panel. Measure DC voltage from the leads that connect to the battery. They should read around 6 Volts DC. If the charging circuit is bad, it will cause a low battery trouble and the console will need to be repaired or replaced.
Hope this helps.
Feb 19, 2011 | GE Security Simon 3 Wireless Home Security...
I replaced the battery on my GE Simon Security System with a new battery yesterday 27 hours ago and still get the low system battery alarm. I upnplugged the transformer disconnected the batterty and...
Did you run sensor test(drop down cover enter you code pess test button then done button. let run 5 min. close cover press status button If that fixes great. If not, you need multi meter. remove battery put metter on leeds coming off panel. You should see voltage there at least equal to the battery. If not then you may see the the red wire for battery has a lump in it about 1" long that is a fuse. remove wire from panel and meter for resistance/continuity/ohms what ever you want to call it. if there is no resistance or an open ckt then replace that wire.if you see resistance in wire then you have a bad panel. GL.
Oct 24, 2010 | GE Security Simon 3 Wireless Home Security...
I have a brand new GE Simon 3 system and am getting a low battery warning. Does it need to charge for a few days out of the box, or was i given a bad part?
No it does not need a few days 12 hrs should have been enough. you will need a multi meter to check this. pull battery off panel after confirming leed where connected properly. meter battery. I believe its a 6v battery should read 6.25-6.5v approx. if so check volts on the leads should also read 6.25-6.5v appox. if so try running sensor test. open panel door look for red numbers enter your code then select sensor (test) then "done" wait 5 min then close panel door. Then press status button. if this does not solve problem. time for service call.
Feb 10, 2010 | GE Security Simon 3 Wireless Home Security...
Have a issue that indicted a low battery replaced the battery have 7.1vdc at the main board when checking system status still saying low battery,
disconnect battery put dc meter on wires. should read over 6v if not need new panel. if over 6v put system in sensor test wait 5min then close cover hit status 2 times. if reset great. if not try another battery. repeat sensor test. if resets great if not need new panel. : (
Nov 30, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
Simon 3: A remote window sensor downstairs creates a constant Low Battery beep/message.
it should be a 6 volt, 1.3 amp hour battery. you can get them at batteries plus. best bet is to take the old one with you to the store to ensure that it fits.
Jun 14, 2008 | GE Security Simon 3 Wireless Home Security...
System Low Battery
Response 1 is correct. If you plugged the transformer into an outlet before connecting the battery the system wont see the battery and give you that error. Should be a simple fix however. Unplug the battery and then the transformer, then reverse the process. Plug in the battery and your Simon should power up, then plug in the transformer. If this doesn't help then you should replace the battery. Did you buy the system from a dealer and have it professionally installed or did you do-it-yourself? If it was professionally installed have your technician come back out to diagnose/replace the battery if needed. Good Luck.
Feb 10, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
539 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Electro Med Services...
Are you a GE Home Security Expert? Answer questions, earn points and help others
