Question about Dewalt Heavy - Duty 18 Gauge 2" Brad Nailer Kit Reconditioned - D51238KR
Dewalt dc608 motor wont run or shoot light stays
Dewalt dc608 motor wont run or shoot,but light stays on
    President:
  • 583 Answers
Seek advice at TOOLKING
Posted on Jul 26, 2009
Dewalt dc616 comes on, wont shoot, flashes 5 times, shuts down.
if new, take it back and replace it.
if old, contact dewalt.
Mar 24, 2018 | Dewalt Air Tools & Compressors
My brand new dewalt cordless chop saw wont work when i pull the trigger the blade jerks and the light and motor gos dead ,thats happening with batteries and inverter
The first thing I'd check is running it with the blade off . Could be locked up somehow. I'd also check the spindle lock . If it's stuck down it locks the gears up .
Sep 18, 2017 | Dewalt Saws
Dewalt dc618
If the motor runs and stays running when you depress the nose then the problem is in either the trigger switch or the solenoid.
If the motor runs for a moment and shuts off with the light blinking I would check your battery. These are very temper mental with voltage, and even if your battery just came off the charger & might work in a drill, it may not have 18v to supply the electronics.
Please note - these are not easy tools to work on, I would recommend bringing it to a qualified repair shop near you.
Feb 09, 2014 | Tools & Hardware - Others
I have a dewalt dc618 finish nailer When I go to shoot the lights on the gun start to flash and will not shoot ?
Continuous flashing indicates low battery charge or poor battery connection. If lights flash 4 or 5 times indicates possible control module fault.
Oct 28, 2013 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
My brand new DC608 18 gauge nailer jams every time on the 2nd nail.
Per your addendum I would have first told you to check that you are using the proper guage nails. Second you should make sure you are loading the nails in the lowest channel in the magazine so they are at the bottom of the magazine. If you load them into the top of the magazine they have more time to go off course before they get into the wood.
May 29, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
I have a DC608 cordless nailer that will not fire the driver the driver does not move at all but everything else seems to be functioning properly Thanks Tim
You can go to this webpage and download the owner's manual which gives instructions: http://servicenet.dewalt.com/Products/Detail?productNumber=DC608K
You can also download a parts diagram and order parts here.
I looked through the manual and found that DeWalt's Brad Nailer does not require tools to remove jammed nails from the nose piece. I believe this is the problem with your nailer, unless it's empty. Some of these nailers will not fire if there's less than 6 nails in them.
Another feature on this nailer is the trip lock. It is a safety feature that prevents accidental firing. Any time you adjustments made to the nailer will automatically turn the trip lock to lock position. You'll find this lock on the right side, under the Dewalt label.
The instruction manual will explain all this.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Dewalt DC608K 18 Gauge 2-inch Cordless...
When battery gets plugged in lights come on but nailer wont fire
Does the motor run but does not fire a nail? If this is the case chances are the belt came off the flywheel. This is one of the most common problems when these will not fire.
If the headlights go on but the motor does not run it could be a bad switch or contact trip.
This a PDF of the owners manual, Page 9 had some trouble shooting tips. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/644429-00,DC612.pdf
This is an exploded view of the tool http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=34790&typeId=9472&documentId=23898
From www,dewaltservicenet.com you can get the contact info for you local Factory Service Center if needed.
For safety remember to always remove the battery when performing any service to this tool.
Oct 10, 2010 | Dewalt DC616KA 18 - Volt 16 - gauge...
Porter cable roofing gun
The problem that you describe could be caused by three things. First remove the cylinder and look for a black rubber band around the cylinder about med section. There is an indention with holes where it is supposed to be. The band should fit snuggly so that it does not slip off during use. Secondly, check that the piston oring/plastic ring holds the piston in the cylinder without just dropping under its own weight. Third, the upper bumper could have a crack or missing piece. Remove it and check. (vinyl part in headvalve) Parts are available at dewalt repair center or www.toolpartsdirect.com. enjoy
Dec 06, 2008 | Porter Cable Cable RN175AR Reconditioned...
Dewalt dc618 wont drive a nail
problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
Dec 04, 2008 | Dewalt DC618KA Angled Nailer Kit
Dewalt nail gun
if ur nail gun is DC608 it on recall. if it other model it could be the return assy or the pc board.
Sep 10, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Dewalt Heavy - Duty 18 Gauge 2" Brad Nailer Kit Reconditioned - D51238KR Logo
874 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
