Question about Mtd Garden
2006 MTD Yard Machine 38 inch 12.5HP won't start. Replaced ignition switch that was corroded and replaced battery. No power at all. Is there a solenoid switch of some kind that could be bad also? Thanks.
  • 1 more comment
  • hudson668 Jul 26, 2009
    I used a screwdriver and jumped the two contacts on the solenoid and it tried to crank. Not sure why but it would never start, but it would turn over fine. Where does this leave me? Thanks.
  • hudson668 Jul 27, 2009
    Yes - It was in the "on" position. I did not have it held in the "crank" position since that would have required another person holding it there while I jumped the solenoid. Is that what I need to do?
    On this mower the solenoid is under the battery compartment in the back. I had to move the battery out of the way and go in through the battery slot. It was not in the dash.
    Problem Solver:
  • 10 Answers
Should be a solonoid under dash when the bonnets open.to check this turn your ignition on start and put a screwdriver from the small wire to the main battery cable going to the starter.if this does not turn the motor over replace the solonoid.if the motor does turn over let me know .
Posted on Jul 26, 2009
  • mark noble
    mark noble Jul 27, 2009
    this may be a silly question but did you have the ignition switch on when you bypassed the solonoid
    mark!
  • mark noble
    mark noble Jul 29, 2009
    thats ok! one more check just to be sure.if you have a multimetre or test light check if you have power at the small terminal on the solonoid, (usually in between the two power terminals) when you turn the key on start.
I can not get my mower started when i go to start it. it will turn over but will NOT start i was woundering if i could get some help with that.
ps.thank you very much
Posted on Sep 11, 2010
How do you find an inline fuse for a mtd riding mower 38 inch cut 14 horsepower
Start at the ignition switch and look for the starter wire..it should be the one tat is slightly heavier and normally red..and goes to the solenoid pos side..good lu k
Nov 16, 2014 | Mtd Garden
Start then not start,no power to inestion or starter ,then start and run a while shut it off then wont turn over again
It may be a bad ignition switch, that or a loose or bad electrical connection somewhere. Check for corroded terminals in the power distribution box near the battery. If no help, you may need an electrical diagnosis of the ignition circuit and the ignition switch.
When it won't respond, do lights and other accessories work? If no, it's a main power problem near the battery or distribution box. If yes, it sounds like the ignition switch or the wiring from the switch to the starter or to the ignition system.
Oct 23, 2012 | Chrysler Town and Country Cars & Trucks
2004 buick rendezvous sometimes won't start. clicks but won't turn over. replaced starter, battery, and ignition switch. what now??
We just went through this with our 2003 Rendevous. Clicking like crazy but wouldn't start. Replaced the starter but still doing the same thing. Our next step was going to be replace the battery (which tested well) and the ignition assembly. Out of frustration, I hit the top of the hood and the headlights came on!! Further investigaton proved that the problem was a corroded ground wire on the battery. Hope this helps
Aug 06, 2012 | 2004 Buick Rendezvous
Need a diagram on how to attach mower deck on 2006 MTD Yard Machine 38" Twin Blade 13.5 hp anybody got one to share or a lead on a .pdf I can download?
Go to...
http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down tp Owners Manuals on bottom left, the enter the model and serial numbers from under the seat and follow prompts to download manual.. Hope that helps.
Jul 05, 2009 | Mtd Garden
Yard machine riding mower will not start
check all of your known safety switches!
Clutch has to be pushed in
seat switch (sit on mower)
blade disengage switch
Finally check your starter soleniod between the battery and the starter and look for fuses and check them out in the process
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Changed ignition switch and put a new battery in now it wont even make a sound was working fine before. but old ignition switch had no keys to it. i was starting with a screwdriver.everything is together...
Different switches can have the terminals in the same place but use them differently. Are the terminal labels identical between the two? Hopefully you made a diagram of the wiring before you made changes. If so, make another diagram showing both switches and what terminals connect in each switch position. Are they the same? If not, figure out how to rewire to get the same functionality. The first mistake in troubleshooting is to think you did everything right. We all suffer the illusions created by memory and our senses which is why we have axioms like "measure twice, cut once".
It worked before you replaced the battery and the switch, therefore doing that work created a problem. The switch using its terminals differently would be a good place to look.
Fortunately MTD has manuals and good stuff on their web site at http://www.yardmachines.com or at http://www.mtdproducts.com
May 12, 2009 | Mtd Garden
Garden Logo
917 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
