Question about Garden
Stop moving craftsman mower run good and move for a wall then it stop moving . dos it need some oil in rear end.
  • mark noble
    mark noble May 11, 2010
    is it hydro drive?
  • fittr May 11, 2010
    want type of mower ..... sounds like boken drive belt
  • 154 Answers
Maybe gear box shot, or hung up
Posted on Aug 05, 2009
My riding mower stops moving forward after 30 minutes of cutting it starts right up the blades engage properly and cuts great it will just stop moving
Check under the seat under the battery box there you should find the drive pulleys for the rear end the belt could be worn out and turned inside out causing it to slip or stop pulling once it heats up mine was installed inside out from Lowes when I purchased the mower causing me to replace the belt hope this helps
Sep 16, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
I have a Craftsman 17.5 hp 42 in.cut riding lawn mower that I've had for about 5 years now, and the rear end is starting to make a whinning sound..How do I grease, or oil the rear end?
It a sealed unit. No service needed. They said call service provider. You tear it apart, if you want. Remove axle from mower. The case unbolt in two pieces>
May 08, 2012 | Craftsman Garden
My craftsman tractor wont pull itself up a hill. Runs fine but just comes to a stop when trying to go up a hill. Maby the ground drive belt is slipping????
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Nov 14, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tracter mower runs butwant move
I hate craftsman **** but check for a broken or loose belt or if it is hydraulic check for hyd. oil.Good Luck..
Mar 23, 2011 | Craftsman Garden
Mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Jul 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rear skirt on lawn mower flips under when backing up
Sounds like the skirt is too long for the cutting height you are using, either raise the cutting height or shorten the skirt. Remember it's a safety guard for trash kicked up when mowing!
Apr 11, 2009 | Craftsman Garden
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
