Question about Acer Aspire 3610 Notebook
Wireless network I have a 3 year old acer aspire 3610 that started with windows xp pro.. but my hard drive went and replaced it and installed xp home edtion would like to know how to get wireless drivers for it
    Scholar:
  • 116 Answers
If it is an internal card you should be able to obtain them from Acers website. If it is an external go to that vendor and extract the files from them!
Posted on Nov 26, 2007
Acer aspire 3610 won't start windows
Do you see any error messages or a blank cursor on the screen? Please add a comment if there are any messages. Some messages might be "missing ntldr" or "error loading operating system".
If you see a line in the upper left corner, that is what I mean by a blank cursor. In that case, the computer can't find the OS or the MBR that tells where the OS exists on the computer.
First remove any external storage devices or non-boot discs. (Disconnect USB floppy, flash drives, or other external hard drives. Remove non-boot optical discs from the DVD drive.) Try booting again in case, the computer was trying to boot from one of these devices. Check that the BIOS is accessible and is set to boot to the hard drive. (To enter the BIOS, turn off the computer and then repeatedly press the appropriate button to access the BIOS. You should see a screen telling you which button to press. This is most often Esc, F1, F2, Del, or F10. If you miss the timing, try again repeat.)
If the BIOS is unavailable, then you have a motherboard problem and need to replace it.
If you can access the BIOS, then get the appropriate Windows OS install or upgrade optical disc. (The Aspire 3610 came with XP. You should match the version (HP or Pro) and the service pack installed.) Alternatively, get a third-party disk management and rescue bootable CD. Set the boot device to the optical drive in the BIOS (or press the key to access the boot menu on restart, if available, sometimes this is F12). With the Windows CD or rescue disk in your optical drive, reboot the computer and let the computer load from the CD.
Using the Windows CD, choose the option for the recovery console and then use the Command Prompt repair. First use the Bootcfg /Scan command to try to find a Windows OS. Next try the command Fixboot C: to build a new partition boot sector. Finally try the command Fixmbr \Device\HardDisk0 to build a new master boot record on the hard drive.
You should also run the program chkdsk /r /f to check if the drive has bad sectors and move data from the bad areas if possible.
If the Bootcfg command didn't find a Windows OS, you may still be able use the preinstalled Recovery partition to return your computer to its factory setting. Check your manual; this will work best if you are using the original hard drive and haven't changed the partitions on the drive. This will cause you to lose your data and programs that have been added to the computer. Alternatively, use your back up system image discs to replace the OS, programs and files to those on your backup.
Usually this sort of problem means that the hard drive is damaged. You should make plans to replace the hard drive. You will need to match the size (2.5") and interface (ATA/100 or IDE) specs. The Aspire 3610 comes with a 40GB or larger drive.
You will need a software program that can clone drives (some may be available with the drive purchase from the manufacturer) and a USB to 2.5" IDE drive adapter. (USB/IDE/SATA adapters are useful for connecting most bare drives to a computer.) Use the cloning software to transfer the contents from the old drive to the new one and set it to become the primary boot device. Then swap the drives. (Disconnect all cables and remove the battery. Open up the laptop and carefully remove the cable. Then unscrew the old drive from the cage. Reverse the directions to install the new drive.) Check the Acer manual for any additional steps.
I hope this helps.
Oct 10, 2012 | Computers & Internet
Acer aspire one nav50 how to install windows on new hard drive
To install windows on a hard drive you have to boot from a CD with windows XP on, after which it will ask you to press a button.
After which you can follow the setup instructions in windows XP.
Mar 01, 2012 | Acer Aspire One PC Notebook
I have fitted a new power socket to my old acer 3610 which has not been used for about 16 months. After reassembly I cannot get it to boot up passed the acer logo bit and all I have is a flashing curser at...
I think you need to loose your system again to see if its components were properly installed.
I believe the had disk is not installed, because if it was installed, the system will boot. So check your hard drive properly and make sure its fixed properly, likewise other components.
Take care.
Nov 28, 2009 | Acer Aspire 3610 Notebook
Aspire 5315 down and out new hard drive, bunch of problems
and home or pro xp will work you should have thexp cd key code on the bottom of the notebook - go to acer .com to download the drivers ..... i can make you a cd for 20 bucks if so email me @ jepito@gmail.com and ship it to you in 3 days the sticker on your pc will tell you what it was xp home xp pro or vista :()
Sep 09, 2009 | Acer Aspire 5315 Notebook
Reinstalled Windows xp professional to my acer aspire 3610
1.change another Installation CD of Windows XP service pack 2 or install Windows Vista.
2. if any track of your CD is corrupted, then this type of error comes.
3. sometime if your hard is not formated correctly, then also some fatal error comes.
4. when formating always do full format, donot do quick format.
Jun 23, 2009 | Acer Aspire 3610 Notebook
Missing Driver for Wireless
Here are the links for the drivers you need.Windows XP Pro 32bit: http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless_Atheros_5.3.0.67_XPx86.zip?acerid=633640465077227028&Step1=Notebook&Step2=Aspire&Step3=Aspire%205100&OS=X02&LC=en&SC=PA_7Windows XP Home 32bit: http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless_Atheros_5.3.0.67_XPx86.zip?acerid=633640465077227028&Step1=Notebook&Step2=Aspire&Step3=Aspire%205100&OS=X01&LC=en&SC=PA_7Copy and paste which ever version you have installed. It should open a direct link to the driver.
Jun 05, 2009 | Acer InviLink 802.11b (91.49C10.002)...
Acer aspire 3000
The bootable XP cd you have will work - You need to first reinstall the Operating System(XP), then download and install drivers for the devices(Such as touchpad, wireless, etc.)
The device drivers are all available from Acer's support site; If the Network Card driver isn't installed after the windows XP installation, you will need to use a different computer to download the drivers, and transfer them to your laptop using some sort of removable media - USB Flash drive, portable hard drive, memory card, etc.
Feb 13, 2009 | Acer Aspire 3000 Notebook
I connot wifi connection on acer aspire 3610 in windows xp
1. check that the ipo address is set to automatic - not assigned
2. try pinging the router - you may be connected but the dns server may be an issue
Nov 18, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
