SOURCE: green light will not come on chemicals are fine
You may have a chlorinator cell that needs cleaning. I usually use muriatic acid diluted 4 to1. Find something you can submerge the cell in and be careful of the acid. If this doesn't help then there is probably something wrong with the cell or the control box.
Happy pool management.
SOURCE: green light for paper feed
paper start sensor is not functioning properly. clean it or replace it.
You need to be able to test at least chlorine, salinity, ph, alkalinity,
and stabilizer. The best way is using test strips. If you have a sample
of water tested at a pool supply store that will work too but frequent
transportation is more costly than strips. The salinity should be about
3000 ppm, Chlorine should be between 2 and 4 ppm, alkalinity should be
between and 80 and 140 ppm and the stabilizer should be between 30 and
50 ppm. Some say up to 100 ppm. Unfortunately higher stabilizer reduces
the chlorine's ability to kill algae, etc. When the water becomes cloudy
it is likely low on chlorine and is about to turn green. If the test
shows low chlorine level then I would add shock to 10 ppm chlorine. If
the filter system is working correctly then it should clear up fairly
soon. I would not let anyone swim until the chlorine is between 2 and 4
ppm and you can clearly see the pool bottom.
If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. Positive feedback is appreciated once your problem
is solved! Thank you.
