SOURCE: Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
SOURCE: How do you replace a door hinge on a Bosch w/machine WFO02464GB ?
Hi, Could I get the model # so I can look it up. I do not believe there is anything that will fall inside the front panel.
With the #, I can be sur.
Thanks
Vic
SOURCE: plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
SOURCE: Hotpoint WD61 - Broken door hinge and bearings
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
