Question about Dryers
No heat checked every thing, + power. took apart all clean dont know how to remover heating elm
  • 867 Answers
Remove the back panel
Posted on Jul 25, 2009
Model lec8858eq2 no heat checked all replaced bad heating element everything else has continuity. Only thing I'm stumped is continuity reads 9 on fuse connected right by heating element help!!!!! W
Check your power source. The controls use 120V, but the heater uses 240V. Also, check for loose connections on power source.
(Make sure power is disconnected when checking continuity.)
Feb 19, 2017 | Dryers
Fujitsu Siemens E620 - i915G does not start. Earlier it made continuous restart cycles. After cleaning a lot of dust from inside of the case it does not start any more. Gives different beep-codes. a - 4...
Remove power cable.
Remove the RAM(s) and clean the RAM slots.
Remove VGA card and clean the AGP slot.
If there is dust on RAM(s) or VGA, gently and slowly wipe with a clean cloth.
Re-insert RAM(s) and VGA.
Reconnect power and start the computer.
Let us know the result.
I must congratulate you on cleaning the machine yourself. Some Fujitsu Siemens machines are so difficult to take apart for cleaning.
Sep 10, 2011 | Computers & Internet
My dishwasher was not using the soap 100% and not cleaning as good as it shoud. I took the middle section apart and cleaned it from debri but now it does not shift to dry. I dont know if I put the pieces...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 30, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Hotpoint nvlr333etowb no heat.
Diode? Ain't no diodes. 3a90295.jpgIf all of theses items check good you might have a burred contact inside the timer. These dryers have a timer that is easy to take apart. Gently remove the motor and cover, look for a burr between the leaf switches. File em down smooth. Let me know.
May 08, 2010 | Hotpoint NVLR333EE Dryer
The top cleaning bar will not spin---water is moving through it but it wont spin--the bottom cleaner spins fine---took it apart and there is not blockage in either of the cleaning bars
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
vvbn
Mar 24, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Dryer turns on but won't heat up or tumble
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Bosch Axxis WTA 3510 Electric Dryer
The vacuum turns off mid cleaning
you have to check the thermostat for any problems.if you find the thermostat with any blackouts or burns you have to replace iot
May 27, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My Kenmore Elite HE doesn't heat
Generally when a dryer does not heat, there is some problem with the heater, either it has shorted because some metalic thing like a coin or pin ( or in our case the under wire of a bra) from the clothes managed to get to the back and short circuit the heating element or the fuse is blown, I am not sure u can take the dryer apart to be able to check with a meter , when it is the heating element. You need diagrams of the dryer to be able to know how to take it apart and to know which screws and parts come off first. Please disconnect the power before attempting any of this
Jan 19, 2009 | Kenmore Elite HE4 Electric Dryer
DRYER WILL NOT HEAT!!! HELP!!!/Kenmore HE3 Dryer-Mod.# 82822102
first its always important that you give make and model as different makes have different repair proceders for repair the easyiest thing to do first trust me is to turn the breaker off then on then try drier and let me know what you found now dont rate me till we are done ok
Jan 02, 2008 | Dryers
Dead ECS G733 laptop
Yes, try replacing the power button assembly first and the heatsink assembly and fan before shelling out big bucks on a Mobo (which is probably pulled from another LT).
Nov 21, 2007 | EliteGroup ECS G733 Notebook
Dryers Logo
83 people viewed this question
Top Dryers Experts
