Question about Garden
Can't restring my ryobi ss30 - Garden
2 Suggested Answers
SOURCE: how do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
Posted on Oct 14, 2009
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
My Ryobi SS30 does not start
check to make sure the plug has good fire if not change the plug
Dec 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do i take a part ryobi cs30 trimmer to replace the pull cord?
Here's a link to step-by-step and a video for a Ryobi SS30 string trimmer. I do not believe there are many (if any) differences between those instructions and you trimmer.
Aug 18, 2010 | Ryobi Garden
Need to get ryobi ss30 weed trimmer fixed,where
If you live in the UK there isnt anyone that will touch these models sorry
Jul 22, 2010 | Ryobi Garden
I need the plug gap for a Ryobi SS30 trimmer
The direct replacement according to the manual is a Champion RCJ-6Y or NGK BPMR7A @ 0.63 mm (0.025in).
Jun 12, 2010 | Ryobi Garden
My Ryobia SS30 SS# ATJ0830439,weed eater, the pull cord will not retract please help Thank You Gail
http://www.ereplacementparts.com/ryobi-ss30-ry30002-string-trimmer-parts-c-7931_15633_15651.html
This is a parts site for you with a schematic so you can see what is going on. I think your return spring is either broken or out of it's keeper. Check it out. hope this helps.
Apr 28, 2010 | Ryobi Garden
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi SS30 Problem, please help
Hello:
Are you Sire you Used the Correct Fuel Mix Ratio?
Remove the Muffler and Look Into the Exhaust Port.
Is the Piston Scratched and Gouged or is it Smooth like Glass?
If Smooth like Glass, then Check the Carburetor for Trash.
If Scratched and Gouged, then the Wrong Mixture was Used and the Engine is Trashed and will Require a New Piston and Jug (Cylinder) Assembly (a new unit will be cheaper than the parts to repair this unit) for the Unit to Run again.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
446 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
