Martha ONeal Posted on May 28, 2017
My kodak easy share 5100 color ink is full but does not print it is new
5 Related Answers
Anonymous
  • 30 Answers
  • Posted on Feb 08, 2008
SOURCE: easy share 5100 will not print red ink
try cleaning the printhead in the kodak aip home center software.
Anonymous
  • Posted on Jul 05, 2008
SOURCE: Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Anonymous
  • 564 Answers
  • Posted on Aug 18, 2008
SOURCE: Kodak EasyShare 5100 All-in-one printer will not print ink
you most likely need to run a head clean and alignment, which is needed after each cartridge replacement.
http://tinyurl.com/6qcpgy
Anonymous
  • 13 Answers
  • Posted on Oct 11, 2008
SOURCE: Kodak Easy Share 5100 will not print after I changed black cartridge
Press copy and photo at the same time and print a demo sheet. Look at the eyes of the two kids in the picture, if they look like zombies, your printhead is clogged. try cleaning the printhead and print the demo again. If it's the same, you need a new printhead. Call Kodak.
David Shaub
  • 2994 Answers
  • Posted on Jan 31, 2009
SOURCE: calibrating 5100 kodak all in one easy share printer
Go to the printer maintenance program and select "Calibrate printer".
Koadak easy share all in one, won't print in bacl
Check the version of AiO software you are using. We had to re-install the Aio Kodak software yesterday because the print que did not register when I changed the ink cartridges. The AiO would scan, but the computer side still thought it was out of ink.
Perhaps the latest software will fix your problem too.
Juliasew
2answers
I attempted to print but the ink is not working. I recently installed new ink cartridges and the color indicator shows that both color and b/w are full
Hi, the is a problem of dry ink on the cartridge. you must remove the cartridge and try cleaning with a soft cloth, preferably damp. after cleaning, you should see ink coming out the cartridge when you simply press/bring the cloth near the passage. Last option, immerse only the lower part in warm water for 2 mins.
Ihave the easy 5100 and it has brand new ink
Did you run the Clean Print Head feature? Did you align print heads and make sure everything is aligned? There are a few tests you can do to make sure everything is lined up correctly. If you need help, try here: http://www.kodak.com/global/en/service/products/ekn033539.jhtml?pq-path=9098
I have a Kodak Easy Share 5500 AiO Printer. I was
Bad new catridge not impossible, I would return the catridge to the store.
Both Ink Lights Keep Flashing
You might have a printhead problem. Call 1.800.421.6699 to get a new one.
1helpful
2answers
Flashing red check ink lights
printer had an error that couldnt be fixed so had to replace it.
Easy share 5100 will not print red ink
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
