Question about Refrigerators
Not cooling first the refrigerator started slowly not cooling and now is not cooling and the freezer side is doing the same. Started a week ago.
  • 286 Answers
Make sure everything is running. (compressor, Condensor fan, and evaporator fan) If everything is running then does the back wall in the freezer have frost buildup? If yes then its a defrost problem. If no frost and everything is running usually means a sealed system problem. Also make sure the condenser is clean.
Posted on Jul 25, 2009
My freezer has started to frost over. It started about 2 weeks ago and is getting worse. What is the cause for the automatic defroster to stop working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from 911.servicetoday.com
Nov 06, 2009 | Kenmore 53092 / 53094 Side by Side...
The refrigerator side started not cooling last week just half way up the fridge. Now the freezer half way up is not freezing.
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dhjhdg
Oct 26, 2009 | Samsung 26 Cu. Ft. Side-by-Side...
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Freezer refreezing continuously
Yes the defrost system is not functioning properly. You will need  a Ohmmeter to properly diagnose it. If you are going to tackle it and need to know what to check, let me know. If so the defrost thermostat (clipped to a freon tube near the top of the coil in the freezer) Should be closed when its below 20deg and open when its 50+deg. Also the heater should have somewhere between 10-20ohms reistance.
Oct 21, 2007 | Frigidaire FRS6R4E Side by Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
