Question about Dryers
Maytag dryer with no heat
It runs but there is no heat and nothing is getting dried!
  • 867 Answers
Heating element needs to be replaced
Posted on Jul 25, 2009
5 Suggested Answers
jonniewalker
  • 1031 Answers
SOURCE: My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Posted on Feb 21, 2009
SOURCE: Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Posted on Jun 23, 2009
  • 121 Answers
SOURCE: I have a MD7600 maytag dryer. It runs but it will
when you turn it on give it a few minutes and see if you see a glow. that will be the ingnitor.if glowes low or dont see a glow at all then id say you have a bad ignitor. if you see a bright orange glow then id say your gas valve is bad. the ignitor is located next to the gas valve, usually their is a peep hole in the front of the dryer that you pop off (dime size cap) and you can look in hole and see if you see a glow. ignitor price roughly 20-50 dollars. vale can be pricey. 50-145.00 dollars part only. labor ingnitor 75-125 and for valve 85-165 depending on were you live and who you use. usually one or the other not both and seldom a thermostat could be bad.
Posted on Sep 17, 2009
  • 905 Answers
SOURCE: No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Posted on Jan 04, 2010
Maytag Centennial Gas Dryer: Only runs in "Air Fluff" setting. If any other setting (Normal Dry / Timed Dry) are used the dryer shuts down immediately. If I force the dryer to run by holding down the start...
Hello Kevin;
My name is Peter. I am a retired field service appliance technician.
When you run your dryer on fluff you are not using heat. The burning smell is when you use normal dry and the lint starts to burn. This will shut your unit down.
You just need a good cleaning. Nothing major. Send me your model number and I will help you.
Dec 11, 2014 | Maytag Dryers
Dryer ldg490 will dry on timer dry but runs forever on permapress (not much heat) what sensor is bad ?
sounds like bad timer points, they tend to burn and get stuck on some places ?
Oct 02, 2014 | Maytag Dryers
Naytag model D8300 Automatic dryer runs but does not dry?
Maytag dryer has one of two issues element/element sensor or board fuse blown, you must expose the board and test the circuts to see if you are getting a complete circut
Jun 13, 2012 | Maytag Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
MY pye2300azw maytag dryer does not seem to be heating hot enough. can you suggest a solution please. Does it need a new thermostat, nothing wrong with the heating element.
Number 10 is the most likely suspect. The blower wheel tends to get wobbled out and won't send enough heat through the drum making it take twice as long to dry the clothes.themobilian_13.jpgthemobilian_14.jpgthemobilian_15.jpgthemobilian_16.jpgthemobilian_17.jpg
MORE HERE
Nov 02, 2010 | Maytag PYE4558A Electric Dryer
Dryer not heating
There is a heating element or thermal coupler that go out on Electric dryers.
May 29, 2010 | Maytag MDE2400A Electric Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Wont dry
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
May 03, 2009 | Maytag Neptune MDE4000 Electric Dryer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
Nov 24, 2008 | Maytag Performa PAV2200
Dryers Logo
43 people viewed this question
Top Dryers Experts
