Question about JVC Audio Players & Recorders
Jvc rx 509v playstation 3 audio audio output
I have a JVC rx-509v reciever and i cannot seem to get the output from the av multi out to work with the receiver. any help?
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
tech48
  • 624 Answers
SOURCE: I have a JVC rx-6032v
yes, you must use the setup menu and assign the optical input to the input you are using. Some receivers have a "input mode" switch. If this one does, you only ned to press it until it says "optical". If you have a owners manual, it will decribe all the settings that need to be made to accomplish what you need.
If you do not have one, I have uploaded one to my website for you do have. It will only be there for a limited time before I remove it, so get it quickly. You need Adobe Reader to read this, so if you don't already have iton your computer you can download it free here:
http://www.adobe.com
Here is the link to the owners manual:
http://www.get1here.net/rx-6032v-ownersmanual.pdf
I would appreciate a "FixYa!" rating for this free information and manual. Let me know if I can be of any further help.
Dave
Posted on Jul 12, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
SOURCE: XBOX 360 to JVC RX 5060b
I had the same problem. You should check to make sure that the switch on the XBox cable is set to HDTV and that you change the resolution on the XBox to 720P/1080i.
Posted on Mar 07, 2009
How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
On the front panel ONLY:
1. Press ADJUST so that the MULTI
CURSOR up/down buttons work for
adjusting the sound.
2. Press MULTI CURSOR up/down
repeatedly until "BALANCE"
appears on the display.
3. Press MULTI CURSOR left/right to
adjust the balance.
• Pressing left decreases the right channel
output.
• Pressing right decreases the left channel
output.
please rate my solution.
Jul 04, 2011 | JVC RX-5000V 5.1 Channels Receiver
How connect to tv
http://resources.jvc.com/Resources/00/00/96/LVT0380-001A.pdf this is a manual for the rx 6000 it's the same connections as my reciever pioneer hope works...............video out to TV, all components video in to receiver
Feb 20, 2011 | JVC RX-884V Receiver
Hi, i have a jvc rx-5022 vsl reciever. I have just put in a samsung blu ray player and have noticed the reciever picks up dolby, true hd , dts all in 5.1, but when i watch a blu ray with pcm audio 5.1, it...
Check the audio settings on your receiver and make sure they match those of the output on your blue ray. Also make sure you are using the correct inputs/outputs on both
Sep 08, 2017 | JVC RX-6030V Receiver
The sound cut off for a few seconds when the reciever warm up
mine did this too, just before the dsp board went. start looking.
Jan 10, 2009 | JVC RX-6040 Receiver
No subwoofer output
yes, you do have to set up the sub output in the reciever.
May 17, 2008 | JVC RX-8020V Receiver
Dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Feb 03, 2008 | JVC RX-7030V Receiver
"OVERLOAD" APPEARS
Have a service shop check out your protection IC and related network...accordianman
Sep 06, 2006 | JVC RX-554V Receiver
225 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
