SOURCE: nissan sentra 1995 wireing help
go to crutchfield .com and let them know your car and your stereo. they are great at this.
SOURCE: audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
SOURCE: Identifying color coded wires for trailer hookup
get a cheap 12 volt test ($6 any parts store) light and have someone operate the different lights while u proble the wires, when the test light illuminates you tag that wire for what circuit was activated, brake, running, turn etc.
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
SOURCE: 1999 dodge ram 3500 cut factory trailer wiring
Check out this link www.dodgeram.org/tech/mods/electric/trailer_wire.htm
