Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
HP pavilion ZD7255EA
Hello, I have a HP Pavilion laptop (ZD7255EA) and the screen has gone completely blank on it. - Usually after seeing a green vertical line and chquered pattern. The other day I had a NVI lop which I cured by doing a Windows restore. Do you think this mioght be a graphics card problem - If so how much would a reapair cost ? Thanks Barry
Re: HP pavilion ZD7255EA
The card probably has a loose chip. needs repair.
Posted on Dec 13, 2007
0 characters
3 Points
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 '
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | CD Drives
I attempted to upgrade the RAM on my HP Pavilion zv5000. (the one under the keyboard) when I tried to turn it on, there is just a blank screen. Any idea what the problem is? The laptop was installed...
According to the link below you can do the upgrade. If is not working, make sure you have the memory seated correctly, then mix and match the memory and switch slots to find the problem memory. It may be incompatible with either the motherboard or the other memory sticks, or just a bad stick.
Apr 21, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
How do i replace the screen on a hp pavilion laptop?
Hello loughran0,
The best way would be a call to HP. If that doesn't work, a visit to a local computer shop or a service center for HP would be a good idea.
Hope this helps & best of luck!
Art Pena
Tech Support
Nov 23, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Display is bland on power on.
Three long beeps is usually a warning that the video card or RAM may be gone.
Oct 13, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion notebook's screen is too dark to see!
do u have a external monitor,connect it up and see whether,u r output is any better..
Jul 22, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Hp Pavilion zd7000 turns on and off with different colored screen
The graphics chip needs resoldering (reflow). Got the same laptop in for repair yesterday. At first when power cord plugged in all LEDS stay, hard drive spins but fans don't work and nothing on screen. A bit later everything's dead. I've seen too many HPs with poor soldering issues. can't really say they're making good laptops these years.
Mar 28, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Trouble with running a secondary monitor from my laptop
Hello tonyphats,
How are you trying to use the monitor? Just connecting it to the laptop? I know on most laptops you have to select to use the external monitor it won't just come up. You usually have to hold down the 'Fn' button and then press 'F5' or 'F7' to toggle between - monitor only, monitor and lcd, and lcd only.
If you are trying that, what happens? Does anything show on the screen?
Dec 20, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Nov 21, 2007 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    The screen goes blank at start up
    If you can not see anything, then it may be your inverter (Replacement part cost is around $50.00), if you can see a dark image then your CCFL (Cold Cathode Fluorescent Lamp) is out. (Replacement part cost is around $15.00)
    Check websites like
    Oct 16, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
    HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
    125 people viewed this question
    Top HP CD Drives Experts
    Brian Sullivan
    Brian Sullivan
    Josh Whitehead
    Josh Whitehead
    Are you a HP CD Drive Expert? Answer questions, earn points and help others
