How do you know if your PMS system can operate with the Mitel SX-200 EL/ML Superconsole 1000? How do I know if it ever has, I am a new manager to this property.
SOURCE: Mitel superconsole 1000
Yes, there are things you can do to clear the locked out phone.
~ The locked means something is wrong with the phone -or- wiring to the room from the Mitel system...
Locked out is like leaving your phone off hook too long, you get that irratating beeping noise, then when the beeping stops, the phone is locked out to save power going to the set.
Ok ~ the first thing I would try, go to the set and play with it, hang everything up and test to see if you can get dial tone... the next thing is change out the telephone set, and test.
If you changed out the telephone set, and there is still a trouble, there maybe a wiring issue, in which case you will require a cable tech to test connectivity...
SOURCE: Mitel SX-200 D PBX generic 1003 ACD- doesn't support ISDN.
You are not going to get the ANI information you need from the current configuration, the only way to get that information is thru the use of PRI.
We have the same problem at our hotel.
You can't fix it at the console, you need to go to the room and unplug the guest's phone from the wall for 10 seconds... reconnect and it is fixed.
SOURCE: Is there anyway to disable operator assisted calls
Yes there is. Unfortunately, this is something that you should contact your vendor to set up for you.
